Wiring up consult port????
Steve Lloyd
I have the write-up on how to wire the engine harness up, but how do I hook up the consult port?? I guess I'm missing something...........I have an S13 redtop in my S14 chasis. The motor is wired up just fine..........
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
the S13 motor is OBD1, it cannot be connected to the consult port, thats what the little blinky light is for
Vanguy
Car: 1995 Nissan 240sx SE
You can hook it up in a '95 as they are OBDI also. You just need some pinouts from a better equipt member. If I recall from when I bothered to look at it. Its only 4 wires, Tx Rx Power and ground methinks.
Steve Lloyd
bump!!!!!!!!!!!!!!
IanS
my car is a 95 and it was obd2 till I did the swap, what do you need a consult port for anyway, thats what the blinkey light is for
whiplash willy
Car: 93 Coupe 90 SR Hatch
The consult port is nice to have, if you are like me and have a 98 typex SR that doesn't have the blinking light on the ECU. I have some diagrams at home I will post later. If you don't have the plug you can pull one from a newer nissan. I grabbed mine from a newer altima.
Steve Lloyd
that would be great, thanks.........
and I want my consult port so I can use my scan tool on it...........
codyace
Car: S14 w/redtop
SideWays=smiles wrote:the S13 motor is OBD1, it cannot be connected to the consult port, thats what the little blinky light is for
If you don't know, don't post. You couldn't be more wrong.
White/Black - PowerGreen/White - ECU Pin 14Black - Engine GroundGreen/Black - ECU Pin 7Green - ECU Pin 15
Modified by codyace at 8:10 PM 5/30/2007
Modified by codyace at 8:11 PM 5/30/2007
Modified by codyace at 8:12 PM 5/30/2007
Steve Lloyd
so none of the wires on the F3 plug from the body side go into the consult port?? Or are the three ecu wires you mention the ones on the F3 plug???I have those colors on my F3 plug, thogh they are different pin numbers, they do say consult port on them. Also, are those pin numbers from your Kouki or for my 95 (Zenki)?? I appreciate the help.
