Wiring Specialties »
https://forums.nicoclub.com/wiring-specialties-u27774.html
Thu Feb 11, 2010 10:01 am
Stephan,
I feel terrible that our mistake ruined the swap for you. I know not much can help at this point, but for whatever its worth, I am sorry for having put you through the experience.
Its been a year since you and i worked on the swap and we made tech support changes internally based on this issue. We do a lot of harnesses on a monthly basis and unfortunately mistakes happen. Having the signal and ground MAFS wiring switched is a rookie mistake and i can't figure out how i was not able to diagnose it. I do it every day. Part of the push back is that I talk to dozens of people every day that have engine running issues that they quickly attribute to the harness, no matter who did the wiring conversion. It's simple to point at the wiring.
Well, the great news is that with our new pre-made SR and RB harnesses, the human element is removed for the major part. All harnesses are manufactured to the same specifications, in large quantities and are bench tested prior to shipping. The factory manufactures vehicle, robotic and construction wiring, so i am very impressed with the quality and the testing process. I am very excited to finally be able to offer a replacement wiring solution for our swaps.
I shot you an email a couple of weeks ago.Also, the no power in the car symptom is a chassis harness bug.
ThanksYury
