moso »
https://forums.nicoclub.com/moso-u137641.html
Wed Sep 14, 2011 12:35 pm
im not quite sure i understand. the ignition has a few different key positions, LOCK, ACC, RUN, START. if you accessories function while the key is in the acc position but not the run position then your problem may be located in the ignition itself. if your accesories function while the key is in the run position with the engine off but not when the engine is running then that makes me believe its relay related.
