JonPowell wrote:I apologize, it is the top coolant line. My mistake. It has been so long since I looked at it....Sorry
It's all good, just want to make sure we're passing out good info.
vududoc wrote:yeah people can also use that lower rad hose insert for an aftermarket sensor off the ka aswell. it beats having to re invent the wheel
Just replacing the RB one with the one from the KA and wiring it takes about 10 minutes. The Blue/blk wire runs to the white RB plug that Opensource talks about in his thread. Then you connect it to the Blue/Blk on the Brown S13 gauge cluster plug that is next to the ECU
Opensource hope you don't mind me borrowing you pics for a little while.
The white RB plug
http://azparttrader.com/rbhelp/IMG_2526.JPG
The Brown S13 gauge cluster plug
http://azparttrader.com/rbhelp/IMG_2522.JPG
I think thats it, I can't remember if I had to connect it anywhere else. I would just trace that wire all the way and make sure it's doesn't have any disconnects in it. Like I said it only took about 10 mins.
Mike
