FlatBlackIan wrote:Really?
How did EVERYBODY miss that I posted a link in my previous post to the FSMs for every 240SX? Just pick your poison and download the PDF.
well i got your link thanks
sjbsuperman1425 wrote:venom, yes, if u remove the wiper motor and then turn the motor on from the wiper switch you should see the motor turning. that means ur connections and motor are good. try it at all speeds too
while its out, grab the wiper arm and blade assembly and move them. if they move ok, then there is nothing blocking the linkages.
i thinks its going to be the wiring cuz when i put the new wiper motor and connected it to the linkage i turned it on and nothing happened. before i put the wiper motor i moved the wiper arms so thats fine.
