Darius »
https://forums.nicoclub.com/darius-u5470.html
Sun Apr 19, 2009 7:17 am
Firstly, 56K you don't have a snowball's chance.
Here's what I've been up to this winter. Things have finally culminated minus a PS issue that I've narrowed down to a faulty pump that I bought from a guy in AUS...to be continued. Other than that everything else has has worked out well.
I am still having coilpack misfiring issues, but I haven't gotten a chance to tackle that until this afternoon. Again, ...to be continued.
So this year I wanted to upgrade the braking system and PCV system and it snowballed a bit.
I installed a Z32 master cylinder, Z32 aluminum calipers with Project Mu NS pads up front, rebuilt S14 rear calipers with Hawk HPS pads in the rear, new SS lines all around, Summit line lock, and new hard lines to tie it all together. Still don't have the line lock wired in, but it will be cake. Chased brake fitting leaks all around, but finally found that Loctite sealed the 1/8"NPT threads the best.
With the new Z32 brakes, the FR500s no longer cleared so I bought a set of silver Work XD-9s. I am going to have a center cap fabricated for them because the Work cap is fugly. I transferred the Dunlop Direzza Z1s to the front and bought new MT drag radials 265/40/18 for the rear. They're tall! The wheel offset is also very aggressive in the rear (+18) so I rolled and pulled the fenders about an inch with HYBRIDRB's help.
I replaced all of the wheel studs with longer Peak Performance studs and new lug nuts. I did this because the FR500s were too thick at the flange and I bought the studs before I realized the wheels wouldn't clear the brakes.
For the PCV system, I replaced the ugly rubber hoses with baller SS braided line and fittings. I also reconfigured it a little bit and am venting it in the fender well about 1-foot in front of the tire. And no its not spraying oil all over the tire causing me to wreck. I also made some isolators for the valve cover hardware and replaced it with something shiny I'll make you a set for $20. l0nestar had me make him some black ones and they turned out nice
The TopHat/Core transmission mount is a flimsy POS so I had a custom one fabricated to replace it. I can also have these made up for about $50-60 each but I need more interest before dropping $1000 on an order out of my own pocket. This thing #1) fits perfectly and #2) is stiffer than hell.
If you've been paying attention to the forum lately, the "RB--->A/C" thread shows some of the pics of the AC adapter blocks that I've had fabricated. They fit awesome and I just need to get hose ends and hose ordered to make up a kit. If you're interested, the price will be around $150-175 to start. The wiring is simple and up to you to do.
Here are a couple of overview shots after I got a chance to wash it:
My favorite!
Me and my pup Harvey
The show-garage after a good reorganizing session
Gat-damned leaky PS pump that entrains air and doesn't work worth a $hit. Can you tell I've spent a week on this thing and still haven't fixed it? Hopefully I don't have to get paypal to get some money back.
