jamesblonde82 »
https://forums.nicoclub.com/jamesblonde82-u38650.html
Fri Nov 30, 2007 7:37 pm
i just got done putting in my window after cussing at it a lot. it's actually not all that hard, you have to remove the whole assembly that the window attaches to, which is just three bolts, one on bottom behind the bottom cushion of the seat, and two up top. take the cotter pin out of the control arm, window has to be about midway up and take arm off and let it rest downward....then slide window down by hand.....then take the nuts off the three bolts, might help to screw the bolts in some so they arent so badly in the way....then slide out towards back of car tilting and moving it around object then pull out. if i knew so many ppl wanted a write up b4 i did this i woulda taken pics, but anyone can ask me if they have any ?'s.....oh and a major tip....the plastic pieces that break, they can be stressed unnecessarily if you don't have your stopper screws not adjusted correctly. make sure the window stops on those and not the top of the car, but make sure its far up enough to seal properly. and grease your tracks like a mofo or the evil monkey will come from your closet!
