elwesso wrote:..... unless of course you want a new windshield.
So a couple weeks ago I was washing the windows on my car and noticed I had a TINY rock chip at the base of my windshield (where the wipers are). It was proabbly about the size of the tip of a match.. I know that you can get those tiny chips fixed for relatively cheap and it will prevent the windshield from getting worse....
I figured I wasnt going to be driving the car for a week or so, so I'd just get it fixed in a week or so. I put a small piece of electrical tape so that water or dirt wouldnt get into it...
Fast forward to this weekend... It was beautiful outside and I was going for a nice drive up to the lake house, but the car was kinda dusty so I decided I'd hose it off real quick before I left. As soon as the water hit the windsheild, CRACK. Now I have a crack going the entire height of the windshield, and I get to buy a new windshield.
I work part-time for my son who owns an auto glass company. I call on insurance agents to try to get them to send us their windshield replacement jobs and repairs, so I know a little about auto glass.
First, windshield repair will NOT keep a windshield from cracking. It is a cosmetic repair only.
Second, never try to replace a windshield yourself. That requires extensive knowledge and skill. I recall one member here who wanted to pull a windshield from a wrecked car in a junkyard and install it himself in his Q. Bad idea, and terribly false economy, which probably wouldn't work anyway, and would likely result in the replacement glass cracking eventually and/or leaks.
Many States do not have what is kown as "full glass coverage" at all, and some do have coverage but have a deductible. Here in AZ, we have "full glass coverage" with NO deductible, and surprisingy, it's relatively inexpensive. Be sure to discuss with your agent exactly what coverage you can get, what it will cost, and what the terms are.
If you do get your windshield replaced, NEVER, EVER use those represented by hawkers at car washes, gas stations, or in TV commercials especially the ones that offer free diamonds, steaks, dinners, or other come-ons. They almost always use aftermarket glass, which frequently is of poor optical quality, and frequently doesn't fit properly. See, aftermarket glass manufacturers re-use the dies they that are used to cut the windshield too many times. Each cut removes some of the die. When worn, the glass ends up being cut too small, and results in cracking and/or leaks. OEM glass OTOH, requires that the dies be used only a limited number of times, and is carefully checked for optical distortion. That's why OEM glass costs more than aftermaket glass. Sometimes that distortion is not apparent, but can result in eye strain and even headaches. Don't use the 800 numbers insurance companies use to get your windshield replaced either. They usually use el cheapo glass companies that employ beginning techs and aftermarket glass. Instead, use your insurance AGENT to personally recommend a local glass company that he works with and that he knows uses OEM glass, and has qualified techs. If he refuses to recommend someone, get a different agent that doesn't want to just blow you off and send you to the 800 number. This kind of agent only wants to get his commissions on your insurance and isn't willing to help you like he should. Some of my best agent customers learned the hard way from sending their customers to the 800 number and got too many complaints. After a few instances like this, they use us and our GOOD local competitors in rotation, selecting only 3 to 5 of those companies that take good care of their customers for them. Take advantage of your agent's value of you as a customer, and his personal knowledge of the auto glass business.
Here's some insight on the glass companies who use come-ons. Reputable local glass companies cannot afford to wait 9 to 12 months to get their money. If they bill the insurance company direct, which by law, they can, they wait for their money. So they bill through what is known as a glass network, of which each insurance company has one they use. These networks get the money to the glass companies quickly and without undue delay, but they set the heavily discounted price. They leave enough for the glass company to profit, but not overcharge them or make excessive profits. Because these better local glass companies work through the agents, they almost always use OEM glass and have highly qualified technicians. As an example, most of the "come-on" glass companies use aftermarket glass, and pay beginning techs $7 to $9 per hour, and require them to do 10 jobs per day, including travel time. We and our good competitors use OEM glass and pay our techs a lot more (because we have to in order to get good ones), and require a minimum of 6 jobs per day, with a maximum of 8. As an example, our newest technician hired a year ago makes $26 per hour. That's what it took to get him. Since we work through agents, we absolutely MUST have top technicians. The come-on glass outfits charge the insurance companies full list and inflated labor charges though, and since they make so much money, they can afford to wait to get their bucks. It's not to the benefit of customers though.
Do NOT shop by yourself for windshield replacement based on price. You WILL get what you pay for. Instead, once again, rely on your insurance agent to send you to 2 or 3 to compare prices from
Elwesso, your windshield will likely not just fall out. They're made to not do so. But you could get a citation for having a cracked windshield, illegal in many States. Call your agent, and even if you don't have full glass coverage, ask him to recomend a GOOD local glass company that uses OEM glass and has exerienced technicians. ALL of the good ones will come to your home or business to do the job, so you won't have to worry about getting the car to them and leaving it all day, depending on someone else for transportation to and from their shop.
Anyone in AZ who needs a windshield, PM me and I'll take good care of you.Just be sure to remind me that you're a NICO member so I can be sure to "Red Carpet" you like I do for relatives and friends.
Modified by StarPD at 1:04 PM 4/23/2007
Modified by StarPD at 1:17 PM 4/23/2007
