qship96 wrote:isnt the OEM factory glass around 700-800 dollars? I had mine done a few years ago,and remember it being pricey
Q45 glass is indeed expensive. Thanks to the antenna and rain sensing stuff, windshield for my 2005 Q45 is my cost over 950. It also requires TWO trim kits at $130 each plus the glass, and that's at actual net cost. It is a dealer only item, no OEM glass from distributors, and not even aftermarket glass. Backlight is similar in cost. Labor is not included in these figures, since I not only get the glass and trim at cost, I get labor free.
If you don't have glass coverage now, I strongly urge you to get it before a rock breaks yours. Cost for coverage is much less than glass replacement.FWIW, summer is coming, and that's when our business increases dramatically due to the heat, so do it now BEFORE you need it. Some insurers will insist on inspecting the car before issuing gass coverage to make sure people don't break their windshield and then get coverage.
BTW, not sure about F50 or Y33, but G50 glass comes in either blue or bronze tint, depending on paint and exterior color. If you need windshield replacement, be sure to insist on the original color.
Infinitis aren't cheap.
