BoyWonder »
https://forums.nicoclub.com/boywonder-u12909.html
Wed Jul 07, 2004 2:42 pm
I'm pretty sure I know the answer to this question, but I'll ask anyway; you didn't do any overclocking or anything of the sort? If you have memory instability while trying to copy setup files, you're going to get strange behavior. My suggestion is go into the bios and reset to defaults. That should set it down to safe settings. Another thing you can do is go download this memory tester (which is free and quite useful, by the way) and check to ensure your memory is still good. Another thing you can do to be real sure bad hardware is not getting in the way is to pull out unnessecary components such as the sound and network card from the computer. Also make sure any and all USB devices are disconnected. That's all I can think of at the moment.. my ideas are a bit more extreme as far as troubleshooting, maybe someone else can throw out something a little simpler to begin with.
Edit: Also, did setup get anywhere before? I mean, I thought you were at least able to boot into Windows before. Did the condition degrade on it's own or did setup get somewhere once, crash, and never worked again?
