The owner's manual might give you insight on how to reset the auto-up/pinch feature, but these links might prove to be more usefull.Dallasguy wrote:Thanks for the reply.
What you typed makes sense. Unfortunately, when I bought the Pathy a couple of weeks ago it did not include a manual. I will see if I can find one online.
I can't believe the problem or the how-to isn't in the FSM. Is it in the owner's manual or is it one of those things that just gets passed from one ownere to the next?Buzzman wrote:It is not the switch, and you won't find anything in the FSM either.
It would appear that it's one of those secrets that gets passed from one owner to another, or across forums like this.The first time it happened to me I asked several service advisers at the dealership what they thought it might be. Not one of them had the solution, and if they did, they kept it to themselves.One adviser just said I should lube the window channels, and it would go away.Yea right.K03sport wrote:
I can't believe the problem or the how-to isn't in the FSM. Is it in the owner's manual or is it one of those things that just gets passed from one owner to the next?
