Thank ya sir, I'm going to be getting them in the black chromium finish.BRicci wrote:Will fit, 235/45 is prolly the best imo.
Thanks! I will be ordering them in about a week. The main thing I hated about my car was how narrow the wheels are that will be fixed with these wheelsMr.HacKeR wrote:235/45 are best, but 245/45 will work too, just in case you want the back tyres to be a bit wider.
BTW, nice wheels!
Thanks, any recommendations on brand?Mr.HacKeR wrote:I think you should also get 10mm wheel spacers, at least for the back tyres. Don't worry about rubbing, you won't rub unless you lower it on coils. You can decide later once you put the wheels on! Good luck
Obviously H&R is the best out there, but I currently have Ichiba. I've had them installed for quite sometime now, no issues at all! But, you should read this thread2011ACdarkslate wrote:Thanks, any recommendations on brand?Mr.HacKeR wrote:I think you should also get 10mm wheel spacers, at least for the back tyres. Don't worry about rubbing, you won't rub unless you lower it on coils. You can decide later once you put the wheels on! Good luck
