Yes, but make sure that they are for the Altima (5x114.3, 66.1mm center bore)czonin wrote:These the ones you have? Some local guy is selling them for pretty cheap.
If you saw someone doing something you knew was unsafe, would you say it looks ok and do it too? That's 10mm less thread for the lugnut to hold onto to keep the wheel from coming off, think about it and tell me that's fine, afterall, the only risk is wrecking your car for the 100 bucks (for 20) they probably costBRicci wrote:Considering people run them without, I think they're fine.
I had Ichiba spacers with extended STUDS and the extended studs broke on me so this happened...wade001 wrote:If you saw someone doing something you knew was unsafe, would you say it looks ok and do it too? That's 10mm less thread for the lugnut to hold onto to keep the wheel from coming off, think about it and tell me that's fine, afterall, the only risk is wrecking your car for the 100 bucks (for 20) they probably costBRicci wrote:Considering people run them without, I think they're fine....
[/quote]Yea, I meant studs. I'll edit my post. Not sure how it happened lol but it wasn't funMr.HacKeR wrote:oh no.. I mixed between lugs and studs!![]()
I think most of us did in this thread.. Sano, I think you meant studs right?
How did this happen? More info please!
I currently have extended studs and stock lugs!
These would work, but I'm not sure about the quality..These look okay to everyone? http://www.ebay.com/itm/HUBCENTRIC-10MM ... 84&vxp=mtr
The whole argument was about replacing your studs lol, so ya you can do that!So do you have to replace your studs from behind the wheel hub? I wasn't aware that you could do that haha.
That's the only thing i'm worried about. Did a simple Google search on them and I found a few reviews. None of them had anything bad to say:Mr.HacKeR wrote:These would work, but I'm not sure about the quality..
I'm sorry, did you say make?AlexN09 wrote:I have always felt like I could make my own spacers pretty easily and a heck of a lot cheaper than they sell them for.
If it doesn't fit the bolt pattern or the exact bore size your whole car is gonna be shaking! what will you use to make it anyways?AlexN09 wrote:yep, I don't understand why it would be so hard.
