Unless you plan to go offroading you're not going to bottom out and smack the fender. Especially in the rear. Especially with the stiffer Eibach or H&R springs. And especially with the slight negative camber that would result.boystar22 wrote:Looks great! I need the opposite though myself. I need to have the hubs on my rears shaved down they stick out about 2-3mm. It doesn't look bad, but I'm too afraid that if I drop it at all I'll rub. Curse this staggered setup!
Hub rings and spacers are not the same. You could install hub rings yourself in 10 mins.psi101101 wrote:i got no offset but i got 20s and my OEM hub ring installed for 50 bucks from this place i knew from a girl and he said he was doin me a favor.. i guess i believe him now.. compared to your 180 bucks..haha
LOOKS CLEAN!!
LongBeachCoupe wrote:LOL PSI.. zilla is right...
A hub ring is a washer that goes inside the wheel, you dont need a tool to put it in, it just slides in, maybe rub some glue on it so it doesnt fall out on tire rotations... If you can change a tire, you can put a hubring in.
Spacers on the other hand require you to take the studs out of the hub and if they dont give you an angle to replace them, removing the hub and/or other parts.
Yes, and I was able to remove a stud myself. However, the Ichiba studs are 10mm longer, and I wasn't able to get the proper angle to stick it back inside. Maybe there is another way, but I couldn't see any alternative.AZhitman wrote:Nice improvement.
Although, the studs CAN be done without the assistance of a shop. All Nissans are designed such that the studs can be swapped without hub removal... I've swapped studs on at least 5 Nissan cars, including my G Coupe.
Those are called "type 2" by Ichiba. However, in this case the stock studs will be too long. Only 25mm type 2 spacers will clear the stock studs.Andy_G wrote: What about the Ichiba spacers that allow you to bolt on to the old studs and then extend new studs for you to bolt the wheel on to?
Those would require no removal of studs and I think they are about 135.
