As DKAS said, a proper search (not just a 1 minute quick glance) will yield great results. Because something is buried in a thread for another mod doesn't mean it isn't worth reading. To get a full understanding of what you need to do to achieve your results, you will need to spend hours upon hours reading. Your questions won't be answered in 5 minutes by search or any particular member. Don't take that the wrong way...take it as constructive criticism. This topic has been covered:1080Rider wrote:I've been reading these forums for the answer but the info is usually buried in a post about a different mod... In any event, I was reading the G37 forums and they seem to think intakes and cat-back exhausts are giving them hp gains. I can't imagine the two operating systems w/ the same motor are so different that one car would benefit and one wouldn't. Are they imagining things (the placebo affect is easy to get) or can we get a hp out of some mods? Just looking for some info from people that have installed some parts and see if they noticed any difference.
IIRC, car (at least the V8) runs a little rich from factory so when you add parts you're making that even worse. I know my back bumper had the black 'soot' from all this horsepower...once I got tuned that condition subsided quite a bit. My rear bumper was recently repainted and after a week, no black soot yet lol.PostalsQ wrote:BTW, I remember someone here gave great advice on the mods. You may be doing more damage to your car after without tuning. So the computer I'm sure is trying to compensate for the extra breathing. And I've noticed and smelled that the car seems to be running rich. Which is not good. I think it might be the culprit to my SES light popping up. And I suspect maybe the rich condition did something funky to the sensor. And then a torque converter was suggested to me. Which I agree with. But damn if they're not money!!! So after headers. I'll think about getting the level 10 valve body. Cause rebuilding this trans is not in the budget.
Believe it or not my car was actually running very close to the factory air/fuel ratio targets even with the HPS Intake Tubes, K&N filters, and 2.5" X-pipe setup. Cutouts opened leaned it out about 0.3:1. Factory air/fuel ratio targets were high 10s and low 11s at WOT. Cutouts open I was running 11.5:1. I now target 12.46:1 and it runs great.Ilya wrote:IIRC, car (at least the V8) runs a little rich from factory so when you add parts you're making that even worse. I know my back bumper had the black 'soot' from all this horsepower...once I got tuned that condition subsided quite a bit. My rear bumper was recently repainted and after a week, no black soot yet lol.PostalsQ wrote:BTW, I remember someone here gave great advice on the mods. You may be doing more damage to your car after without tuning. So the computer I'm sure is trying to compensate for the extra breathing. And I've noticed and smelled that the car seems to be running rich. Which is not good. I think it might be the culprit to my SES light popping up. And I suspect maybe the rich condition did something funky to the sensor. And then a torque converter was suggested to me. Which I agree with. But damn if they're not money!!! So after headers. I'll think about getting the level 10 valve body. Cause rebuilding this trans is not in the budget.
I have the same intake tubes and exhaust set up (minus the cutouts). Stock tune. I am using the stock filter boxes and ram air plenum, but I drilled a series of holes in the filter boxes to simulate the Eventuri ram air intake system I saw on the Audi R5 someone posted in another thread.DFW2011M56S wrote:Believe it or not my car was actually running very close to the factory air/fuel ratio targets even with the HPS Intake Tubes, K&N filters, and 2.5" X-pipe setup. Cutouts opened leaned it out about 0.3:1. Factory air/fuel ratio targets were high 10s and low 11s at WOT. Cutouts open I was running 11.5:1. I now target 12.46:1 and it runs great.
I have looked at the intake very briefly, but this spring I plan to open up the boxes a little and maybe see if I can put some conical filters in them. We have a type of cold air setup already so w/ a little modification it seems that we might be able to improve upon a decent design from the factor. I'll look around for the post you referenced above. It's cool to find out that others have done what I was planning...armybrat wrote:
