707 »
https://forums.nicoclub.com/707-u46617.html
Thu Feb 08, 2007 10:58 am
ok this is wierd... so i just put in my redtop sr. it was running fine with open downpipe for a few days then i put the exhaust on. a couple miles down the road it began to cut out when i got on the gas. after looking around under the hood for a few minutes i found that the nipple coming off the wastgate had broken off and the hose was just dangling. after JB welding it back on the problem had stopped. a couple hours later i went for a drive and it was happening again but the jb was holding up, no leak. basically heres what happens, if i drive without stepping on it itll drive fine, idle fine and pretty much run perfect. As soon as i step on it it sputters. the wierdest part is, it does it the worst in 1st gear, a little less in 2nd and by 5th it barely does it. I have no boost controller but its boosting around 12psi. I have checked so many things but still cant figure it out maybe there is something i have forgot. the fuel pressure is fine, there seems to be no leaks in the vaccum lines, i tried 2 different sets of spark plugs (no change). what else can i do???
