:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Mon Jun 02, 2003 6:41 pm
For one, stock compression is 9.5:1...
And 10psi won't magically blow out your rings...bad tuning will. I detonated at .4bar and destroyed a ring land, but others with better (fuel and timing) tuning run 12psi daily and 15psi for fun on stock KAs, and have been doing so for a couple years. TY in AZ (White '97-98, F-max Stage II) is an example, as is Dennis in ATL (unSTABLE-Hybrids guy...White S13) - They both run JWT setups.
Hell, Dennis made 357rwhp with a T3/T04E, no exhaust, and 15psi, stock block.
I think people see 10psi as the limit is that *most* low-buck KA turbos setups run 370cc injectors, which won't get you much past 10psi on a decent sized turbo...the limit is more like 265-275rwhp.
To go bigger means $$$ injectors like drop-in Tomeis/Nismo and such, or custom fuel rail with top feeds, etc...
So the KA limit isn't 10psi, but for most of us without HUGE power goals, might as well go with an inexpensive solution that will get you twice the stock HP output - Boost to 8-10psi with 370s.
Later - Brian
