C-Kwik wrote:Try testing something. I'm not sure where you had your wastegate signal before, but if you have a port at the compressor housing, hook your boost gauge into that. Make a run and make sure the boost coming out of the compressor is similar to that in the manifold at WOT. If it is, try removing the signal line for the wastegate and make a run. To keep from overboosting, go part throttle, being careful not to boost much until you get near the RPM the boost drop off occurs at. Make a few runs gradually increasing throttle at these RPM's to see if the pressure increases at all. This will rule out any wastegate issues.
Getting a pressure reading at the compressor outlet will rule out any boost leaks. This would limit the problem to the turbo itself or the exhaust end of business. From here, I'd check for exhaust leaks.
With the motor cold, visually inspect and perhaps feel around for soot around any of the joints and make sure there are no cranks. A small turbo will see a lot of backpressure, especially towards the upper RPM's where efficiency drops off. The problem may be occuring only at these high pressures. Fortunately, exhaust leaks are usually easy to see evidence of since they do tend to leave soot around the leak. Any of the joints could actually be lifting, or a gasket may be leaking at higher pressures.
I used to have the wastegate signal coming from the compressor housing, but, at the suggestion of someone in this thread, I hooked it up to a T that comes off the intake manifold so it's getting its signal from there. My boost gauge and wastegate now get their pressure from the intake manifold, so I could hook up a gauge to the compressor housing (I happen to have a very accurate mechanical 20 psi gauge that will do the trick).
As I've said before, there's a leak in the EGR tube that used to plumb to the stock exhaust manifold....I'm not sure if this causes any of the boost problem, but I don't hear air leaking out of it when I pressurize everything. Also, I've had recurring problems with the gasket blowing out where the downpipe bolts to the turbo...so exhaust gases could be escaping from there. But again, would exhaust gases escaping from the turbine outlet (where my 3 bolt downpipe flange bolts to) cause a boost leak?
Also, I tested the pipes/intercooler again today after JB welding the crap out of all of them, and I couldn't hear any leaks. So I went ahead and attached my cold pipe back to the throttle body to pressurize the intake manifold, and I can't pressurize the thing to more than 3 psi, whereas I could pressurize the pipes/intercooler to 15+ psi.
I hear a pretty substantial leak coming from, as I guessed, the inaccessible back-side of the intake manifold. Unfortunately, it's nearly IMPOSSIBLE to get at anything back there wedged up against the firewall.
Anyone want to take a guess as to WHAT exactly is leaking back there?
Here's a picture of all that junk at the back of the intake manifold, including where there's a crack in the EGR tube:
