MarkEmark wrote:I'm stumped...I thought the fact that I got 15 psi up to redline by carefully regulating throttle input ruled out the turbo not being able to build boost....but it HAS to be something with the turbo.
These are the specs for my cams:
Intake 221 duration @.050” .379 lift; (272 advertised duration), .380 lift; Exhaust 231 duration @ .050" lift, (278 advertised duration), .390 lift.
These are the specs for the PDM stage II DOHC TURBO cams. They seem to have very similar specs, minus the duration, of course. But could that much more duration cause the described symptoms.
STAGE II DOHC Turbo Cams – Intake 221 duration @.050”, .380 lift Exhaust 221 duration @.050” .380 lift
Basically, they're identical to my cams except that mine have 10 degrees more overlap on the exhaust cam. Would 10 degrees more overlap cause an instant 5 psi loss like that? Perhaps?
Couple of things. Modultating the throttle to build the boost to 15 psi at the turbo doesn't prove anything. Building 15 psi there is not hard under part throttle conditions. Keep in mind that with the throttle partially open, there is simple less airflow. In order to build more boost, for a given set of conditions, you need more airflow. If you are at WOT, you need to flow more air to build 15 psi at the compressor than at 50% throttle. To do this, the turbo needs to work harder. Also, if there is a leak in the system, it would not be apparent here. Since a turbo compresses the air internally, it will read whatever pressure the air is at as it leaves the turbo. If there is a leak later down the plumbing, it will show the pressure drop at the leak.
The overlap in the cams could be an issue, but I doubt it would get to 15 psi then drop down rapidly. It would simply struggle to boost the right amount entirely.
My thoughts are it is something that shows itself at higher pressures. Kind of like a valve that opens and allows a leak once a certain pressure is reached. I really think it sounds like a hose coupling.
Adding onto a previous question, at what points did you cap off the piping to pressure test it?
