USDM_OneVia »
https://forums.nicoclub.com/usdm-onevia-u6319.html
Mon Feb 02, 2004 7:36 pm
See the little arm thingy coming towards the firewall off the cold pipe? I used a couple of pre-bent 90 degree bits of vacuum hose I had laying around and just kinda worked them into the IACV, so it is hooked up.
I am using the S13 SR20DET GReddy VSPL kit with a GReddy S13 SR20DET hotpipe. All worked out great for me. Only thing I had to do was buy an extra 3 inch coupler to connect the cold pipe after I had to cut it in 2.
Basically all you do is cut the cold pipe about 3 inches from the IACV port, rotate it about 45 degrees to point to the throttle body and you are done! It was pretty easy.
I got my GReddy from ebay for 705 shipped, so it was a pretty good deal. And BTW Jon, I calculated it out, and the GReddy core is larger (more volume) than the HKS core so that is why I went with the GReddy over the HKS or I would have bought it. Don't know about the Blitz core though, never really considered that kit.
If you guys have any other questions, fire away!
Joe
