Whoreing kenrick style (pics of the SPL 350Z track rotors installed)
Jookmasta
out of curiosity what tint is that? great looking car and good stuff on the brakes...............u need not spend any more money on upgrading the front brakes lol.
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
Jookmasta wrote:out of curiosity what tint is that? great looking car and good stuff on the brakes...............u need not spend any more money on upgrading the front brakes lol.
the tint is 25% metallic not that dyed crap that turnes purple after a year in the sun i really like it, has a mirror touch to it in a way
gabossie
Car: Your mom
DAYUM that is sexy!
AmoebAssassin
Car: 1991 Base fastback 5spd, black
Holy **** that is so baller status!
MagikDragon
Car: 1991 240SX, 1992 240SX, 1986 MB 190E 2.3-16
MagikDragon wrote:all you need is a redrill, the ebrake assy does not interfere at all w/ the hubs.so the answer is YES.
its an awesome setup, and don't forget the 300ZX BMC
I Lied Todd!
I found out that the ebrake assy doesn't interfere with the hub itself or the drum setup on the rotor BUT it does interfere w/ the bearing housing, which seems odd to me. If you have more questions about this ask Bart aka Tenkawa Akito, he has tried this setup.
eddiec
Car: 91 S13
this place has some good info The Definitive 300ZX Brake Swap!
Poor_S13_Driver
Car: S13
Awesome brakes man. Do you have any lock up with the front brakes? Ive read a lot of scuffle about how big brakes are pointlessos a 240 because youll just lock them up. Are you having any such issues? Again awesome job
spider_slayer
Car: S14 240SX
S13 240SX
the rotors scare the wheels into stopping. it has nothing to do with leverage or any of that.
it really is time to look into some other calipers. it jsut looks odd.
RB20DETodd
spider_slayer wrote:the rotors scare the wheels into stopping. it has nothing to do with leverage or any of that.
Fronts good enough for now, but yeah the calipers look kind os small wheel hides a bit, if i ever did more it would be the brembos of the g or z that go with them prolly need 18's tho , im more worried about the back now.
spider_slayer
Car: S14 240SX
S13 240SX
maybe not 18's. but some more clearence at least.
i think there was a theard a while back about the brembos bloting up to the stock location with a bracket.
so to run the brembo's would you have to blot both brackets to the hub or would the spl one work??
94_240sx
Car: 94_240SX
I've wanted this setup ever since RB20DETodd posted pics, and finally I got them.
Modified by 94_240sx at 8:31 AM 11/14/2008
adrianfromthecastle
Car: 1992 Nissan 240sx
wow man. those look great!!
hows the feel? feel much of a difference between stock z32 rotors and the SPL rotors?
tramp_drift240
Car: 1992 240sx SE Coupe
woooooooooow 94.
i need to know your exact brake setup.
and wheel size please.
zomgggggggggg
94_240sx
Car: 94_240SX
adrians_s13 wrote:wow man. those look great!!
I've never had z32 rotors, so I wouldn't know the difference. I took your recommendation and got the Project Mu B-Force pads front and back. Initial bite is amazing, and I like the setup. It's still in the middle of breaking in process, so I don't know its full potential yet, but I did about 100mph on the highway, and I had no problem slowing down and accelerating again.
tramp_drift240,It's a typical z32 setup with caliper brackets to install 350z rotors.You need 17 inch wheel to make it happen. Mine is 17x8 +38, but I have 15mm Ichiba spacers, so offset is +23. Because of the spoke design, mine will clear without the spacers anyway. I'll do the full detailed write up soon. I'm going to compile everything in one thread, so it'll be all you need for z32 brake swap.
Nacho_240
Car: 1991 240sx LE
That setup looks aggressive. I love the sharp look of the iron calipers too. Very nice
94_240sx
Car: 94_240SX
Nacho_240 wrote:That setup looks aggressive. I love the sharp look of the iron calipers too. Very nice
Thanks. They are 30mm Aluminum, not iron. People prefer aluminum because it's lighter I guess.
Modified by 94_240sx at 8:29 AM 11/14/2008
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
Nice setup.
Nacho_240
Car: 1991 240sx LE
Looking at them closer I can see that they are the aluminums. My bad...
BTW, I read somewhere that the iron versions have a greater heat capacity so they don't dissipate as much heat to the rotors. In extreme cases. the aluminum calipers can also warp.
tramp_drift240
you definitely need to do a write up on that janx.
you normally have to have at least a 17" wheel for brakes that size, luckily ive got my handy Cr Kais that'll be going on shortly after i swap my motor into the new(ish) coupe.
i was looking at the stuff PBM has, its like 350 or something for a pair of 13 inch rotors and brackets for 300zx calipers.
but yes, write up, ASAP. i must have larger brakes behind 18 inch Works.
georgegto
Car: Nissan s13
edited...
Modified by georgegto at 11:32 AM 7/30/2009
