lyon23 »
https://forums.nicoclub.com/lyon23-u15440.html
Wed Jun 04, 2008 3:45 pm
When you you download Live Edit look for the config files for the rb20 open the file with notepad. Then download tuner pro and look for the 300zx xdf file. open the 300zx.xdf file and on the corresponding description right click and select edit item XDF info and enter the address shown on the notepad for the rb20(tuner pro first item is injector k value look at the rb20 config in the notepad for kvalu and enter that address and so on for the rest of the items that live edit provides). Then save it and make a new xdf for the rb20. The 300zx xdf has more options than the live edit but I do not kow where those values would be located on the rb20 but when you open them on tuner pro some numbers seem to make sence. One item in the 300zx.xdf file is an item called "unkown-parked rev limiter" and the item is set at 5100 rpm.. Can you say 2-step..
