Who's actually DONE an LS1 / 240SX swap?
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
crzycav86
Car: 93 Nissan 240SX KAT
http://www.houston240sx.com/fo...16044
ls1 swap into an s14. The guy is really friendly, so don't hesitate to ask him questions on aim.
Swedish Mike
Car: Golf TDI, Volvo 850T5 and 200sx S13 Hatch
Guys, a few fast LS1 questions. Is this engine used in C5? Both heads and block in aluminum?
Thanks!
WDRacing
The C5 has the LS6 or LS7 IIRC, but all LSx engines are aluminum block and head. Which is one of the biggest reasons people are swapping them in. The LS1 actually weighs less then the KA24DE. Stock internals are good for 600WHP...its a good motor.
WD
the_momo
Car: 1997 VW Golf K2 (His)/ 2001 Black Lexus IS300 (Hers)
take a stroll through this...youll solidify your decision. its not simply the lsx, its the sbc in general. just amazing really.
http://www.turbobuick.com/foru...sions/
there are people using 106mm turbines. thats unreal.
WDRacing
I used to use that forum all the time for alcohol injection info...good guys.
neoamd
WDRacing wrote:The C5 has the LS6 or LS7 IIRC, but all LSx engines are aluminum block and head. Which is one of the biggest reasons people are swapping them in. The LS1 actually weighs less then the KA24DE. Stock internals are good for 600WHP...its a good motor.
WD
Wrong.
C5 = LS1 C5Z06 = LS6C6 = LS2C6Z06 = LS7Camaros = LS1T/A / FireBird = LS1GTO = LS2
And the difference between the LS1/LS6 is different intake mani/cam/and better heads.. So swap out those parts and it the same damn thing, sounds the same.
neoamd
mikespeed95 wrote:hinson kit is boop. stay away. speaking from 1st hand experience.
Well I will post up my experience from his kit etc as he is putting my LS1 FD together for me right now.
neoamd
tonynalli wrote:
It's too bad that none of us will be able to hear that exact sound. What you have my friend is a kick *** version of the ls1. If this swap is in my future, I would only be able to afford a lightly used ls1, it will be from an older camaro.
But that sound that z06 makes is intense
He replaced everythign that made it a LS6..
Kick *** version of the LS1 = different head/intake mani
Turbo-Zone_com
With your permission WDracing and enough interest, I'd like to offer an alternative to the HSC kit for the swap to an LS1. We all know parts are expensive, so a less expensive alternative is a nice welcome.
A little background on us. We've been in the fabrication/performance/turbo arena for over 12 years. Our fastest vehicle to date is our own Street Bike Shootout bike with a time of 7.80 at 186mph in the 1/4 mile. We won 2 National Championships with it so far.
Thanks for your time, we're always around for questions if you may have some. Thanks again!
John C.
WDRacing
By all means, post away. Any info you guys can provide along with actual mounting options etc is always a good thing.
WD
Turbo-Zone_com
Thanks again for the extended courtesy, we'll try to help where we can.
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
That sure would be a nice alternative to the HSC kit... Myabe by release I could be able to afford it! Any more info on the kit?
574-240sx
Car: Nissans, Toyotas, Subaru
Also some of the late 01/02 LS1 motors in the camaro/TAs have LS6 blocks. I checked my block number and I have an LS6 block.
mxd6
Car: '97 Nissan 240SX
Toyota Camry XLE V6
neoamd wrote:
Wrong.
The LS1 with 350HP/365 FT/LBS. torque came in the 2004 GTO - that is the engine going in my 97 240SX, w/6 speed, headers and cold air intake - stock, it is the most powerful LS1 made. It will smoke the WS6 T/A and SS.With 5,700 miles on the drive train, it's not even broken in. With the GTO fuel rail cover it's going look good under the hood - 10" on the back, fully upgraded suspension and a bunch of other goodies, it's not going to be easy for any N/A or turbo to touch it. The drive train alone set me back $6k.Later a cam and a little head work will take it way over 400HP/475 torque. King of the NISSAN's will be ready in April - Houston, TX.
http://www.speedfetishperforma...id=19
GTR PrYdE
bump for info
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
I want to ride in a V-8 240sx. I see no viable reason to swap it and use it as a daily. d!ck said the v-8 gets better mileage too? What are the numbers on that?
JustinStrife
Car: '99 FRC. 402, Vortech T-Trim @ 12psi = 706rwhp/621rwtq
Actually, if you got the 01'-04' C5 Corvette with the 6spd manual, you got 350hp/375ft/tq. 4spd automatics give you 360ft/tq with the same hp. Probably the same with the GTO.
The 01' LS1's(LS6 block and intake manifold essentially), and 01' LS6's also are notorious for using a little bit of oil. 00's and 02's, don't have that problem(I should know my 01' burns about 1 qt every 2-3k miles).
97-00' Ls1's from the C5's also produce 345hp and not 350, but same tq. Different cam settings that were changed in 01(it wasn't the intake manifold that netted the 5 extra hp as they don't give you much power gain until you start running boost).
As for gas mileage, my 95' 240sx automatic gave me 18-20mpg daily driving, and 26mpg freeway driving 80 on average. My 01' C5 automatic gives me 17(since I installed the exhaust and picked up a lead foot; and I use to get 19-20mpg before) daily driving, and 25-26mpg freeway driving 90-100mph. The DIC says I get 28-32mpg driving 80-85 turning 1800rpms in overdrive. At 140 it said I was getting 20.4mpg!!
Oh ya and I was only turning 3200rpms(with a 6250 redline) at the time.
breadbox
89 Koop
84 720 4x4KC
would the better mileage come from the lighter car?
WDRacing
Gas mileage is very much related to throttle tip in and available torque. By requiring less torque and lower throttle angles, the ecu accesses the higher flowing fuel maps alot less.
So its not so much the motor getting better mileage, its the encompassing situation and environment in which it is used.
A new exhaust has been shown to make you lose gas mileage when in theory, it will improve it. The reason for this is the natural craving to hear the noise emitted from the exhaust with frequent throttle stabs or aggressive driving styles in general.
The Geo Metro can get 50MPG, but it was shown to get close to 30MPG is real world driving with an agressive driver.
WD
Ramsie
Car: A few
Im really interested in how much this type of swap cost and the time that goes into it...
I just baught 2 240sx's and im builing a drift car before the winter time... [dont bash me for this but...] I dont like anything about the way a import sounds.... Ive had experiance with several LSX based engines and they are wonderful. I have a LS1/Built T-56 already - so I figured its worth a shot.
WDRacing
Well if the LSx is going into a drift car, some solid motor mounts should be really straight forward. Also, see if you can get a Skyline subframe. It won't have to be cut and it allows for shorty headers to work. That just leaves the clutch issue and transmission support. I'd just make custom lines for the clutch.
WD
GTR PrYdE
any word from turbo-zone about them building parts for the swap?XAT Racing now has a full LS1 240 swap, it costs from 11k-14k, I just emailed them about DIY parts
WDRacing
Does the 11K include the 240SX?? If so then its a good deal, otherwise...CRACK PIPES ARE US should be there new name....
Turbo-Zone_com
We had a locate on a mock-up car but with all the snow that fell through. No way to transport it...our trailer is buried. We're actively looking for a car still or, if someone who is relatively local, wants to do the swap, we can work out a barter.
Give us a call - 315.395.6525
Thanks!
XofXtimeX
Car: 95' 240
Well at 11k it is still cheaper then Hinson so it's a little better, not that it is still worth it though...They only have the turn key packages on there site though which is kind of annoying.
GTR PrYdE if you get responce of DIY parts would you mind posting them on this thread or e-mailing me at [email protected] what you find out?
WDRacing
I'm such a DIY guy, I always see things as to expensive. Thats always my problem. I have to remember that shops have to do high quality work to avoid getting sued and then they have to have a profit margine as well. I have a hard getting outside the box sometimes...lol.
WD
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
WDRacing wrote:I have a hard getting outside the box sometimes
WDRacing
From what I hear, you have trouble getting any "box" at all
redtop91
Ha! Time for a new intelligence team.
Ramsie
Car: A few
11k for a swap and your out your mind...
What makes this swap so special then all the others? 11k for a LS1 swapped into a S13 and it better have a nice single turbo setup on the LS1.
I havnt heard of anything that overpriced since ive looked at Lingenfelter's website.
Return to “Hybrids”
