Who is scraping?
All things Altima Coupe.
BigDankCloud
Car: 08 Altima Coupe 3.5SE
Ok so correct me if im wrong but for those of you with the BC coilovers... can you adjust the ride height to be higher so that this goes away? Or make the ride stiffer so that you dont squat as much over stuff?
I have the eibachs now and want to move to the BC Racing coilovers so that I'm not bothered by the goddam condition of New England roads with all these potholes and frost heaves. I'm pretty sure my stock shocks have seen better days now anyway.
I scrape now going over speed bumps because of the lack of the shocks being able to handle the weight of the engine dropping on them at like 1mph. Since the springs are the progressive its not that bad of a scrape, but I'd like to see if i can get the same ride height with a better ride.
Anyone able to answer this weirdly worded, long winded question for me?
bunda4th
Car: 2008 Nissan Altima Coupe 2.5S 6MT
You can adjust them height wise and change the damping to stiffer. Mine is already stiff (15 all around). You would probably want to go softer to not scrape so much.
I would raise the car up a bit but I don't like having a gap between wheel and fender.
