s13sr20chris »
https://forums.nicoclub.com/s13sr20chris-u7880.html
Mon Oct 06, 2003 12:05 pm
What is required to make the RB25DET fit into a 240SX?All that is needed is the clip, driveline, tools, patience, and parts for extending/crimping wires.
What modifications are necessary to the 240SX?To make the engine fit properly with stock mounts, you will have to accomodate a few things.
As with any turbo swap, you will need to cut holes for intercooler piping. You will need to shave (using a dremel or similar tool) a small portion of the turbo manifold that connects to the downpipe. This is necessary for steering rack clearance and does no harm as long as you do not shave too much off. You will need to make approximately a 6" cut of the hood skeleton to achieve hood clearance (which isn't visible from outside the car). You will need either a RB25DET driveshaft or a custom one made to fit the RB25DET engine.
How difficult is the RB25DET to wire?When I wired my car, I kept my 240SX interior harness (runs dash, headlights, tail lights, etc...) and got rid of the KA engine harness and ECU. I replaced that harness with the engine harness and ECU from the RB25DET. I then had to extend wires for the Gauge cluster and Ignition so that they would reach the LHD side of the car. I then integrated 5 wires from each of the harnesses ignition systems and made a power terminal where both harnesses were attached at the front of the car so that they would each receive power.
Can you use the Stock RB25DET mounts?Yes, the stock engine mounts are bolted to the stock crossmember which shares the same bolt pattern as the KA crossmember when bolting up to the 240SX chassis. The transmission mount can be used, but must be taken off and flipped backwards. After you do this, you should add a spacer 1.5" thick made out of anything such as wood, metal, plastic, rubber, etc... as long as it will not collapse.
i copied all of that from night szevyn's website. it seems a little too good to be true. what do you guys think? by the way i am on the verge of a sr or rb swap into a 240. its not my car but the guy who owns it is technically inept so i will be doing the swap for a small fee. we are friends so i promised i would get him the best motor i could, but if there are too many extras to buy when doing the swap i will just go sr.
