r1jlewis »
https://forums.nicoclub.com/r1jlewis-u18861.html
Mon Sep 17, 2007 5:19 pm
I'm stumped on this now. S15 SR, new bottom end (rods, pistons and rings), new HG W/arp's, fresh valve job, HKS cams, Greddy springs, bla bla. Now on with the story, compression all between 135-145 accross the board, leak down reads 100in 92 out accross the board. Each one you can feel air out the oil cap so head is sealing good. Problem is that cyl 1 and 2 just don't burn like 3,4! 1,2 are still almost all black while 3,4 are white. Swapped injectors 1,2 to 3,4 and coil packs 1,2 to 3,4. No change, stays with the cylinders. Ohm reading on injectors are all same. All new plugs, tried swaping, no help. ECU is a AEM EMS and shows output same accross the board. Pull coil packs and can hear good fire accross the board. Removed injector harness and check all conections look great. All Ohmed out normal. AEM says it's not the ECU, CFTurbo says it is. Just now baffeled! Car still runs fine, but still staying out of the boost until full dyno tune is completed, but i can't do that until it's burning the same accross the board. Any ideas???
