Which wire to use for a tach signal
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Right now Im in the process of installing an Alchohol injection system into my S14 with a Redtop SR20DET, for the system to work corectly I need a tachometer signal wire that fires once every engine revolution, its the same wire I would use if I was installing an aftermarket tach. If this had a normal ignition system with a distributer and whatnot I would just use the wire on the coil, but with the Direct spark system Im not sure what wire to use, Im thinking I either need to use the signal from the ECU for the tach or one of the wires on the No 1 coil
Any Help is appreciated, and yes I seached, I really want to get this system working befor the weekend
Thanks in advance for the help
Ian
Modified by SideWays=smiles at 12:53 PM 5/24/2007
IanS
bump
I need to get this thing running again
Afliction523
Car: 92 S13 KA-T Coupe
If it is the same as my ka, there is a yellow with a red stripe on the ecu. Im not sure about the sr. It might be the same.
IanS
well, I know which wire it is on the ECU, but Im not sure if this is the wire I should use, Im debating between a wire on the CAS, the ground for the No 1 coil, or the ECU tach signal
IanS
well I tried using the tach signal wire on the ECU, and the system did not activate, I dont think that wire produces the right kind of signal, I need a 1 pulse per rotation signal, cmon guys help me out here.
Afliction523
I would try the coil then. Try it till you get it.
C - ROD
Car: SR20DET pignose hatch
look at the back of ur valvecover on the coil harness, there should be like a black wire that makes a loop on the outside of the harness & that is what u would use in order to check the timing so im assuming that its a good tack signal that fires once oer revolution
IanS
C - ROD wrote:look at the back of ur valvecover on the coil harness, there should be like a black wire that makes a loop on the outside of the harness & that is what u would use in order to check the timing so im assuming that its a good tack signal that fires once oer revolution
yah this is what I plan on trying next, I am out of town at the moment, but I have my tools with me and I have time tomorow Im going to give it a go.
C - ROD
LMK if it works, as i will need a signal for my auto meter tach when i get my motor done
CMG
Car: 1989 240sx Hatch w/ Redtop
Isn't there a tach signal coming from the computer to the dash, orange wire maybe?
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
C - ROD
but will that work with an auto meter tachometer?
IanS
differant tachs work with differant signals, Autometer sells a special unit to connect a tach to a vehicle with direct ignition
stop thread jacking
IanS
Bump, anymore Ideas?
