ROM tuned ECU's are great. Don't forget EFI Specialist. Skip right over the 370cc SR injectors and get the biggest injectors you can find/afford is what I always say. Sidefeeds are notoriously expensive when bought new, because they are kind of niche. Topfeeds are more affordable, although you do have to buy a new rail, you have more options and they are cheaper individually. Most times you are going to have to wire in pigtails for aftermarket brand sidefeeds anyway like you would with topfeeds, but your old factory wiring near the connectors has seen better days anyhow. Also, I like to keep a nice supply of lower o-rings on hand at all times.Feadz wrote:As long as the injectors are sidefeeds they will fit into the stock DE rail with no modifications, some people prefer top feeds, which would require a new rail and some other modifications, but if you're on a budget i'd stick with the sidefeeds to keep the cost down. You should pick up a new injector o-ring set too.
The fuel pump you'll need is a Walbro 255, numerous vendors sell these in the advertisement section here on nico.
Did you pick a plan for engine managment? I'd choose a ROM tune, as suggested above it's basically a plug and play. Enthalpy is running a special for dual tunes pretty cheapand they're up there with JWT.
