Solving your needs for a fuel pressure gauge.
Logan76
Car: Junk
So it has been brought to my attention that many of us fellow 240 owners need a way to view our fuel pressure. I was going to make something for Nico at no labor cost and provide it for material cost, but I found something on summit that works much better. Knowing your fuel pressure is very critical to any kind of aftermarket parts, or even troubleshooting a stock vehicle, so here's your solution.
http://store.summitracing.com/...w=sku
That's a total of 21$ for a liquid filled gauge and a place to mount in inline wth your flex lines on your fuel system.
WD brought the gauge and holder to my attention on summit, I had planned to make one but it was'nt this cost effective.
Razi
Car: Moo
Yay sweet!Thanks Logan. :D
Logan76
Car: Junk
Your welcome broski. Almost all 240 owners who have modified their cars should get this setup. If you have went KA-T ALL of you should have a way to monitor your fuel pressure.
wrgibson
Car: RB Hatch
I run that exact setup....it works perfectly.
ZOMG.SR20
Car: 1990 s13
i must order now
Ninjamasta
How do you set this up? I'm guessing I would need another fuel line going to the gauge or is it electrical sensors?
Razi
Car: Moo
Only have the electronic fuel gauge in your cabin.You don't want fuel spewing all over your face if anything goes wrong.
If it's not electronic, keep it in the engine bay.
Logan76
Car: Junk
Ninjamasta wrote:How do you set this up? I'm guessing I would need another fuel line going to the gauge or is it electrical sensors?
Use the 5$ part by cutting your fuel line and T'ing it into there, then just screw the 1/8th npt fitting on the gauge, into the 1/8th npt hole on the gauge T. Remember NPT is a tapered thread so use either teflon tape or a thread sealant/pipe dope.
It's a mechanical gauge, its located under your hood.
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
Cool, I'm getting this
Logan76
Car: Junk
you should
Warped161
Car: 90 s13 the never ending project
Very cool just ordered it.
Logan76
Car: Junk
Nice, I'm glad I could help out fellow 240 owners, Im ordering the gauge but I have an AEM fuel rail on my LS.
spooled240
Car: kouki s14
what size are the fuel lines on our ka24's? I wanna say 5/16" so wouldn't 3/8" be a little too big?
Razi
Car: Moo
Yeaup, it's 5/16.Lube up and stick it in. Jk, yeah it might be a bit tight.
I'll look around the intarwebs and look for one with 5/16 fittings.
spooled240
Car: kouki s14
razi you sick perv...eeeeewwww! lol j/k
White Comet
Car: fc, s13 and mazda6, Sierra
good info. the funny thing is i have that gauge waiting for me in my toolbox.
Logan76
Car: Junk
3/8 would be a tad too big, but if you put some vaseline on those hose barb's and really wanted it, you could make it work
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
I should invest in this. Checking my fuel pressure every oil change because Im paranoid has become a little annoying.
Steady_One_S13
Car: 1991 SR'd 240sx S13, 1993 Toyota SW21 Mr2...
It's a needed investment.
You guys should get one that is liquid filled. The liquid prevents theneedle from jumping around, and you get an accurate reading.
ZiG
Car: 1993 240sx coupe
Kinda sketch imo, running pressurized gasoline into your car's interior.. I'd rather just use an oil pressure gauge with an electric sending unit.
Steady_One_S13
^Interior? It gets mounted in the engine bay, inline with fuel hose.
ZiG
Yeah I dont like doing that. When it's on the dyno you need someone watching that side of the bay and then it takes a second for them to signal the guy behind the wheel to kill it if something happens. And, well, on the street..
IanS
ZiG wrote:Yeah I dont like doing that. When it's on the dyno you need someone watching that side of the bay and then it takes a second for them to signal the guy behind the wheel to kill it if something happens. And, well, on the street..
They make electric fuel pressure gauges for that. I don't like using an oil pressure gauge for it, the scaling is too high to get a truly accurate reading. Plus, when on the dyno, the last thing Im watching is fuel pressure.
White Comet
spooled240
Car: kouki s14
just bought it
Logan76
Car: Junk
Wow, im glad everyone is actually buying them.
spooled240
Car: kouki s14
summit should give you a small cut for the reference :D
freakyjason
Car: 1990 240sx
I will definitely be getting this setup! I've been worried about my stock fpr after I installed my walbro fuel pump. Good lookin' out man!
Dattebayo
spooled240 wrote:summit should give you a small cut for the reference :D
Make sure they don't cut your wrists, that could be messy.
lucky03602
Car: 96 d21 *work in progress*
01 xj Cherokee auto 4.0 4 1/2" lift 32x11.5x15 family dd
im going to order tomorrow, ill ask to see if they happen to have the fitting for 5/16
