Nismo_Freak wrote:Well... it's a 99+ MY release. Mthe S15 is a newer vehicle built to work on newer grades of oil. The S13 however was developed 15 years ago, and hence may have different suggested oil weights.
When an engine is the same it needs the same oil.Teh only thing that has changed since then is the renewed need to find a trick or 2 to met CAFE.
And <yes> there are different recommendation for different model years.
but if anything as ECU's + Tune's become more aggressive upping combustion chamber temperatures the trend should actually be upward in viscosity recomendations.
the fact that it is the other way around has more to do with considerations other than engine protection now play a role in manufacturers viscosity recomendations.
Fred...
