racin-type wrote:rn240sx - can you please tell me how it is on the streets?
Its fast as hell on the street when u stay below like 90 mph. This turbo a has a LOT of torque and low end power, but when u get into the high speed range, the turbo is just out of breathe and has nothing else..
Quote »like when does boost start to build 2000rpm and when does it start to fall off 5000rpm? does it fall off hard, or just runs out of steam[/quote]The boost builds as soon as 2500 rpm and stays till redline. But once i get into 4th gear... it will hit 20 psi but it wont PULL as hard as it pulls at 20 psi in 2nd and 3rd gears... its just out of breathe...
Quote »So at like 80mph which is about 3000rpm in fifth gear, slight gas will hit 5-10lbs of boost?[/quote]Pretty much, at top speeds when u barely hit the throttle, its into boost THAT fast.. But the problem is this back side, this back side is more for like auto-cross. Quick instant power... but top speed 90+.. its just maxed out and has no more power to give...This compressor i have is capable of pushing 400 whp... but this 48 housing wont allow this compressor to push that much air to produce 400 whp while maintaining good efficiency. I had to push this turbo to 25-26 psi to hit 414 whp but that turbo was MAXED out and the boost gauge was jumping back and forth between 25-26 psi trying to hold solid and im sure it was blowing out LOTS of hot air which is not needed and not good..
Quote »Seems like your willing to upgrade and sell this turbo. Please email me, i'm very interested:
[email protected][/quote]Im trying to see if i can change out to a 63 housing to make this turbo more reliable and allow me to hit 400 whp without having to push 25 psi..If i cant, then ill me more than happy to sell it to u so that i can buy my GT32 or T3/T04E which will let me hit 400 whp with 20 psi or under..
