Ninetyfive240sxSE wrote:i'll go for ka-t, if you rebuild the engine and strengthen it. ca too old of a technology. rb25 kinda hard to install.
Spoken like someone who really knows little about Nissan engines.
The CA is actually more "advanced" than the SR. Cam on bucket (no rocker arms to worry about), square stroke (bore=stroke), shorter intake runners than any other Nissan 4. Yep. SR is the product of Nissans cost cutting in the early 90s.
The RB25 is actually not that hard. As long as you get the mounts from Mckinney or the like to save the headaches, the wiring is really no harder than SR/CA.
KA-T is nice, but yes, needs to be built for high boost. FYI: I have a buddy that has a KADE-T w/ T3, 7psi, stock exhaust and he ran dead even with another fellow that I know SR T25, FMIC, 3" turbo back and 14psi. He has a vented WG so it sounds straight EVIL at WOT. He did it on the cheap as well.
For a daily driver I say KA-T honestly. I LOVE my CA, but the fact that it is pretty torque less makes off boost passing/cruising crappy. The KA-T will also be able to use everything that you already had under the hood (sensors, wiring, etc) that makes a JDM swap a PITA. But any built engine/swap will have its fair share of headaches.
