Where can I buy a CA18DE TOGA High volume Oilpump cheapest?
float_6969
Nice! a new threads with pics of the setup would be great.
tommey
Car: S13 ca18det
I will once i finish it :)
Pic of the pump i am using
bentvalves
Car: 89 Silvia K's
Sweet deal tommey sounds like you've got your hands full. Update this thread with pictures of your insane oiling system in 2014 when you get it all sorted out. No offense. But seriously.
tommey
Car: S13 ca18det
the only thing i havent figured out yet is the crank pulley, should i use an ROSS unit wich i probably can bolt a wheel for the oil pump belt to, or should i modify a stock one.
I think im going to look into the ROSS balancer as that is the most attractive option.
I have the bracket done, but i have to space the pump out according to where the wheel i mounted.
I also havent got the hydraulic couplings yet, and i havent even started on the oil pan.
The CD20 girdle is so massove that i cannot make the oil pan very slim either.
Atleast not with 92mm stroke, might have to make another girdle solution.
float_6969
Since I own a Ross balancer, I would HIGHLY recommend the race balancer, it will make it VERY easy to have a pulley made to mount to it for the pump.
boost_boy
float_6969 wrote:Since I own a Ross balancer, I would HIGHLY recommend the race balancer, it will make it VERY easy to have a pulley made to mount to it for the pump.
Did you mount the magnets onto that pulley? And if so, how did it go? Any troubles?
float_6969
Yes I did, and it was very easy. Easier than the stock one actually because you can mount them to the inner part of the pulley and not have to worry about deflection from the rubber skewing the magnet position.
boost_boy
Good to know and thanks. I juts may venture down that road one of these days, but first I need to liquidate this nissan CA factory in my garage. Talk about excessive hoarding :tisk: .
tommey
Car: S13 ca18det
I emailed them and asked if they have any pump drives wich will fit the CA damper.
How much do these dampers cost?
I also asked if they make a 24 teeth triggerwheel wich will fit the damper, if they do i might buy it form them instead of getting one made.
float_6969
They don't have anything off the shelf, but the design of the damper makes adding a toothed wheel or a pulley for the oil sump, or both for that matter, very easy. There are 8 bolts IIRC on the front of the pulley that would allow you to easily mount another pulley to it.
tommey
Car: S13 ca18det
Yes i think it will be better to choose the ross balancer even if they dont make anything bolt-on.
I will wait for an reply from them before i buy a balancer
float_6969
Just to reiderate, you'll want to get the race balancer, as it's the one with the bolts on the front. The standard balancer basically looks like the stock unit. The only issue this brings up is that the race balancer eliminates the pulleys for the A/C and P/S. If you've got P/S and want to keep it, you'd have to use the standard balancer, and it doesn't have any provisions for attaching a pulley to it.
tommey
Car: S13 ca18det
Oh, thats weird.
I have balanced two RB cranks withing the last few months with these ROSS "race'" balancers on them, and i am pretty sure they had both 'PS and Alternator pulley?
I really dont want to go electric PS.
float_6969
Ross Race Balancer for the CA18DE(T)
Image Image
float_6969
After looking at these pics, I think I just realized why they had to eliminate the P/S on the race blancer. On the RWD CA18DE(T), the P/S is the outer most pulley, and the A/C is in the middle. They wouldn't have been able to save any weight on the race balancer if they tried to keep the P/S. The opposite is true for the RB, with the P/S being in the middle and the A/C being on the outer.
I'm going to be running a Toyota MR2 power steering setup. It doesn't look very complicated, but we'll see when installation time actually comes.
tommey
Car: S13 ca18det
Ok, i will write what ross says here in this thread.
Even if its a little off-topic :)
I might have to use the RB balancer if i choose to use RB timingbelt sprocket and timing belt.
tommey
Car: S13 ca18det
> Hi Tommy
> Sorry for the late reply.
> Just got back from Xmas Holidays.
> We haven't done any research and development for the CA18 in regards to the external sump mounting bracket.
> We usually can supply the balancer but we would have to hand make it as we ran out at the end of last year and currently have other jobs going through the cnc's. $600.60
> We supply 12 and 36minus2 toothed trigger wheels for $308.00 (fitted to balancer or on its own)
> It would cost a bit more to program the cnc mill just to do x1 24 toothed trigger wheel. (approx $528.00)
> Having said that, for a small fee for labour ($110.00) we could probably mount a trigger wheel that you provide onto the balancer for you when we make it.
Seems like an RB balancer is the way to go really.
I still haven't got to measure one, so if anybody here has one and wants to help I would appreciate it :)
float_6969
There was a big group buy on these balancer's when I bought mine, and I think a bunch of the RB guys bought them. I would post up in the RB section.
tommey
Car: S13 ca18det
I have done that now!
Dont know why i didnt think of that myself.
Maybe i will make a new thread about it when i know more :)
ska69
Car: 200sx s13 ca18det
tommey
Car: S13 ca18det
No, still hoping RB balancer will be a nice shortcut!
ska69
why? they are cheaper?
btw, if you need the balancer only for installing a trigger wheels, looks like the KA24E pulley fits.
tommey
Car: S13 ca18det
Because of drysump drive :)
They don't make that for the CA balancer.
ska69
oh :) slipped out of my mind
