I used to have to change plugs about every 10k miles on my older rigs, I haven't changed plugs on but one vehicle in the last 10 years. However on that one it was a challenge. I think you probably can go about 100k assuming you are what I would refer to as an average driver (not necessarily average 'G' driver).byfalisha wrote:Forum...bought my G in summer of 05 with 51K miles...when should I be thining about changing the plugs? No noticable miss fires.
I think they should go much further than that for the average driver (not necessarily average 'G' driver from this forum).tollboothwilley wrote:Most people have found that around 60K miles the gaps are not even. I'd recommend changing every 50-60K miles. Its easy enough...(and relatively inexpensive considering most parts for the car)
He had 51k 4 years ago if he bought it in 05 with 51k on it by the sounds of it.tollboothwilley wrote:Many people have found leaking valve covers when they change out the spark plugs...and most people that have changed them out before the 70K mark when the warrany expires have also notice differences in spark gaps as much as 20-30mm.
No harm in changing the plugs earlier...only benefits.
You just made my point as most people who have 'G's probably don't bother to post to forums. And of those that do the ones that post are the ones that have reasons to believe they need to change their plugs early.tollboothwilley wrote:I'm speaking for MOST people with a G35.
On several forums... for this engine I have seen many spark plugs at 60K miles. I would say that everyone should change them at 50-60K intervals to keep optimal performance.
I'm sure with your 2008 you probably haven't run into any issues and certainly haven't changed out yours yet. I've changed mine and many of my friends all with basically the same result.
And the proven benefit is? I hope you really didn't mean 20-30 mm as stated earlier. that would make for a real long plug.tollboothwilley wrote:I have several friends that are not on this forum Perry. 350z and G35 alike...these are the ones I am speaking of. Plus I have also talked with many people who have more experience with hundreds of vehicles with the same results.
I'm not saying that you can't go 105K miles like the manual states...just stating that it is beneficial to change earlier.
Just to let you know that Telecom is at about 88888 miles and counting. He states that his gas mileage is doing well and he uses that as an indication of how well his car is performing. I agree with this as a good criteria with the only additional statement that I add is under load. Typically a couple of times a week I will listen to the car when cold and when hot at the exhaust. If everything is ok, mpg, under load performance, and sound doesn't indicate any issues then I would consider leaving them alone.byfalisha wrote:Thanks! Perhaps I'll make it a Memorial Day weekend honeydo!
I understand that you can go the distance on the plugs. Hell, you can drive on tires for thousands of miles past their wear bars too...pfarmer wrote:
How often you need to change is of course related to how hard you push the car but if you are a 'normal' driver I believe you should get 100k or more out of a decent set of plugs. If you race all the 'H' cars in the neighborhood on your way home from work then maybe every 5k is not often enough. Just pay attention to the criteria I mentioned and maybe some others of your own and change them when they need to be changed.
Perry
Note that tires past their wear bars start to get dangerous and you experience a decrease in performance.tollboothwilley wrote:
NGK are the recommended plug.
I would go with either the Iridium IX or the Platinum. They run like $9-11 per plug.
Not very often!pfarmer wrote:
How often does Telecom change his plugs? That would probably be a good indication of how often you have to.
Perry
I believe it is simply a waste of money, time, and also unnecessarily exposes the heads to possible damage as well as cylinders to fod if done incorrectly when there are no indications that plugs need to be changed out. I believe an average driver should be able to get close to 100k without issues. Of course if they need to be changed early then every 5 k may not be too soon for some.rpm240sx wrote:HAHA why are we getting so dramatic about changing plugs? If you drive hard and feel like spending a few bucks on some good ol' preventative maintenance then go for it. If you feel the need to wait and do what the manual tells you then by all means wait. I understand the point of, "if it's not broke don't fix it" but if you have the wallet and don't mind preventative maintenance and like to play it safe then change your plugs. I myself change plugs every 50-60K I too have a heavy foot though.
I haven't looked at the Nissans for how the damage could be done, yes the plugs should be cold for the benefit of thermo expansion. However I have seen problems with dissimilar metals as well and damage can occur not only on removal but on insertion. On newer engines the dissimilar metals should not be a problem on removal since this was a bigger issue with the original aluminum heads especially those without inserts and older style plugs. I have seen a lot of articles describe putting various 'Never Seize' types of applications to prevent seizure. This can be a fatal mistake as many products can actually enhance the interaction between dissimilar metals instead of preventing it. Helicoils was often the ultimate solution when things went bad.Poyzinous wrote:you change plugs when the engine is cold. You dont need to worry about damage at that point. You can run a few simple tests to know if your plugs have deteriorated a little earlier than normal. I drive hard, and as a tech, I dont want to run my plugs to the limit, so I'll change them soon Probably after my next oil change.
As far as the coils I was referring to those who are not as careful as they should be with them.Poyzinous wrote:Sounds good. But lots of the guys here driver harder than average...as long as you do your work exactly like it should be done per the ESM, you'll be fine. Here at the dealer its recommended at the 105,000 mile service, sometimes 90,000. The ignition coils only need replacement upon failure though. I'll probably warranty those though
