devilmagic wrote:with both low and high beam on at the same time
wow are the ddms really that bright??? for some reason i have 8k in my fogs & after a while they have a slight yellow to themDJBeasy wrote:I have to once again endorse DDMs. I have 6K highs and lows, no problems...
dont you have a 3.5??? cause then all you have to buy is a d2r bulb & your set, plus its a lot cheaper to buy the bulbsrwong wrote:For those of you that have swapped out your OEM headlights to HIDs, did you change your high beams too? or just the low beams?
i've been thinking a lot about finally getting some, especially since it's about to be winter, and you guys know what a b**** it can be in the cold to drive with fog and s***. lol
what do you mean "blind" when you switch to highbeam, ur low beam remain on at all time still.DJBeasy wrote:devilmagic wrote:with both low and high beam on at the same time![]()
Dont swap the highs. The HIDs take a few seconds to warm up and get to full output, meaning if you flick over to high from low you are going to be flying blind for a few seconds. Then when you have to flick back passing an opposing car, you are again blind for a little bit on the low beam. It woudlnt be terrible but I still wouldnt recommend it.
um both the highs and the lows run at the same time. even if you flick the highs on, the lows are still running and never actually turn off. additionally, when you turn the highs off, the lows remain on.DJBeasy wrote:devilmagic wrote:with both low and high beam on at the same time![]()
lol double post!downedzephyr wrote:woooo devilmagic tag team action going on here
yea i have a 3.5nismogxs21 wrote:dont you have a 3.5??? cause then all you have to buy is a d2r bulb & your set, plus its a lot cheaper to buy the bulb![]()
as for changing your high beams it doesnt really make sense to cause it takes time for the bulbs to warm up considering you only flick the high beams for about 1/2 a second
devilmagic wrote:isn't a pair of xenon bulbs about the same price as the whole kit?
I believe you are confusing terminology my frienddownedzephyr wrote:um both the highs and the lows run at the same time. even if you flick the highs on, the lows are still running and never actually turn off. additionally, when you turn the highs off, the lows remain on.
Is there any hint of blue in the 6000k? I'm not sure what wattage you have...I was just wondering because I want the brightest and whitest light from DDM and I was debating between 5000k 55w or 6000k 55w for the lows, but I don't want any hint of blue in the lights...Which one is the brightest/whitest rating?DJBeasy wrote:I have to once again endorse DDMs. I have 6K highs and lows, no problems...
DJBeasy wrote:And I actually just realized I wrote highs and lows in my post with the pic...stop rubbing off on me!
I have lows and fogs, LOWS AND FOGS!
When you switch from HIGH to LOW or vice versa there is going to be a short period where the bulb is going to have to warm up and wont be at full output. You would be blind because you would be briefly drivng with no headlights...
or maybe it's a go check your car thing. i have 6k low's and OEM highs, flip the highs on and i see 2 different colors on the road ahead of me. somewhat indicative that both my lows and highs are running, especially because i have my fogs turned off. hrmm... i think you, my friend, may be the one confusing your terminology.DJBeasy wrote:I believe you are confusing terminology my frienddownedzephyr wrote:um both the highs and the lows run at the same time. even if you flick the highs on, the lows are still running and never actually turn off. additionally, when you turn the highs off, the lows remain on.
Highs
Lows
FOGS...
Lows and fogs run at the same time, highs and fogs do not, nor do highs and lows. Maybe its a dialect thing...
ddmtuning.comsrwong wrote:i haven't bought anything yet. i've been working on small mods on the coupe right now. gonna have to wait on my next check before i can buy anything. what's the site for DDM? and random question, how much brighter (if any) are the oem highs compared to 6000K
not all 3.5's have stock hid's. unless sam has stock hid's (which i'm pretty sure she doesn't cause she wants to go from halogens to hids) then she needs the full kit.nismogxs21 wrote: dont you have a 3.5??? cause then all you have to buy is a d2r bulb & your set, plus its a lot cheaper to buy the bulb![]()
the reason the oem highs light up the road so much better is partially because they're aimed much higher. this lights up more of the road ahead of you, but also blinds oncoming drivers. if you've driven around with your highbeams on and you feel like it's still not bright enough, then you may want to upgrade to hid highs too, but otherwise just stick to just changing your lows. your lows are your everyday lights so those are more important to upgrade IMO. highs are rarely used and they already do a good jobsrwong wrote: how much brighter (if any) are the oem highs compared to 6000K
