Very true, many times people loose the little cover for the strut. This allows the bearing to dry out and seize up, this forces the spring to twist on its seat, causing popping.Vegascorbin wrote:Strut Mount bearings going bad.
Most people forget that the strut turns when the car does and that the mount has a bearing for this reasion. Not a hard fix just use caution with the springs when you takt the mount off.
Then my best guess would be the mounts.martins_240sx wrote:ill check the strut. but as for the sway bars it was happening before the new ones
Either way there needs to be a bearing that allows the strut to turn. Stock struts have a bearing mounted in rubber. If you have camber plates on your Tein's, then you have a pillow ball, or spherical bearing. It can become seized in the same way the stockers can.martins_240sx wrote:i think you might have been talking about stock struts? mine are tein super drifts....I'll still check cause i got nothin else... if you where talking about aftermarket ones, then my bad
Ive seen a few people complain about this. You need to make sure the bolts attaching your tension rods to your control arms are heeman tight. otherwise they slip.91SilviaKs wrote:I just installed new tension rods and a nismo power brace and since the install, something in the front left of the Silvia has been poping under heavy braking and sharp turning?? Im gonna find out tomorrow what it is...
Rich
Im gonna try this and report back....thanks IanFlatBlackIan wrote:Your symptoms match a seizing upper mount almost perfectly. The sound you are hearing is the spring itself popping as it binds on its perch because the mount is not allowing it to twist.
Pop your hoods, and turn the wheel lock to lock, slowly, watching the strut mounting bolt, it should be turning smoothly with the wheels, if at any time it stops, you have a bind.
