This is what I want!!!!!!Q451990 wrote:
Unfortunately I don't remember who's Q this is, but I think the combination is beautiful! They are FX35 18" wheels.
Heath
I have a set of these in perfect condition in my basement I was going to wait until warm weather to ebay.Q451990 wrote:
Heath
GseaQ, Can you post a pic with that set up. I'd love to see what it looks like. I know Wes has used it, and still believes that going to 26.6 with 245/45 wouldn't hurt anything but I'd like to see it. Also, there are plenty of tires with proper load rating and then some for the Q, and it's what the 540i sport came with .GseaQ wrote:245/45x18 is 26.6" diameter - a tad bigger than the stock 26", but should work fine. 255/40x18 is 26". Our new '95 came with 2004 Q45/M45 18x8 (40mm offset) wheels and 255/40x18 tires. It is lowered with Eibachs and the front wheel arches are rolled a bit. The tires fill the arches without sticking out. ............................Glenn
Lifted79CJ7 wrote: So do we have a list of "interchangable wheels" that will fit the G50 from other Infiniti's? That would be a great sticky for other noobs to be able to check without asking the same old questions over and over again...Jack
Real rivets, let alone fake rivets, should be a clue as to weight and strength. No mention of offsets in either linked website either, nor weight nor strength.maxnix wrote:Rex has a wheel data thread somewhere. Did it ever make it into the Articles Forum?
I do like these wheels, a muscular look but not too aggressive for the body style.Q451990 wrote:
Heath
I didn't think they looked better than the 17" 5 spoke OEM that came with my Q.
The wheels will fit, and the tires (just) meet the 95 minimum load rating, but are a little short and "hard". Ultimately, you'd want a 245/45/18 as a minimum, and something with ~200 wear rating.96’er wrote:Elwesso:
I am thinking about these wheels with the Avon Tech M550 235x40x18 ZR tires, Mille Miglia Evo 5 18" Rims +35 offset.
You stated you have/are running the +35 offset, using this offset versus the +40 will I run into any potential suspension/rub issues.
Thanks,
Patrick
96’er wrote:I currently have the stock 15x6 wheels on my Q
Offset and width together make up the placement in regards to the fender and the suspension.Haitian_King wrote:May be a silly question, but I can't get a visual of various offsets and their appearance on a G50. I'd like for my wheels to be almost exactly even with the wheel well/fender lip, without sticking out. What offset would I be describing here?
