Wheel size question and occasional rough idle..
Nissan 350z / Nissan 370z general community discussion forum
350zQ45a
Car: 350Z, Q45A
I know this is usually fixed by ordering a ground wire set, which I am getting around to doing hopefully this week. However, considering I have a warranty on the vehicle, shoudl I just take it in and let them examine it?
More info: What is the standard Z idle, is it the last mark below the 1k, which Is 750? I notice occasionaly it has a hard time staying at that mark and will dip and increase more then a new(er) vehicle should. It also has a rough idle to it, and maybe a noise, I'm not sure. I suppose I should take it in under warranty, then order the grounding kit?
As for the wheels:
I am picking up a brand new set of Pirelli Directional ZR tires mounted on some sweet OZ wheels. Will this work for the Z?
35 mm offset all around245/45 in the front with 18x8 rim285/45 in the rear with 18x9 rim
Thanks!
PalmerWMD
Car: 2004 350Z
Rough Idle:
Not an unusual problem with our cars.Not all 350Z's have it but a good number do.mine was fixed via a new MAF and a grounding kit.
Other causes have been found too, but most commonly it seems ot be grounds,... about 5 out of 7 PPL with this problem were able to fix it with a grounding kit but not all.
In some cases coil packs or MAFS were found at fault, in one rare incidence the injectors were leaking air at a gasket ( this one is pure hearsay and only one I heard with an injector replated problem).
Depending on the quality of your dealership , they will fix it under warranty no questions asked (albeit they will likely need it for a full day as its not easy to chase these idles down) or they may refuse to worry about it at all if it thorws no codes.
Check this thread for a story on this:zerothread?id=105020
Fred..
PalmerWMD
Car: 2004 350Z
For the wheels/tire combo question I would check our Nico whee;/tire subforum with Moderators more knowledgable than the folks on the "other" sites about this:zeroforum?id=140
Fred..
s13sr20chris
for the record every single z33 i have driven for an extended period of time with consult on it has shown a misfire at least once. i have not gotten anything from nissan fix about it yet but i wonder what it is. i would prob try harder to fix it but i have not had to yet.
PalmerWMD
Car: 2004 350Z
Under what condtions?
Idle?Did they have grounding kits?
SmithSR
Car: 240sx
350zQ45a wrote:Will this work for the Z?35 mm offset all around245/45 in the front with 18x8 rim285/45 in the rear with 18x9 rim
The +35 on 8" and 9" should tuck nicely into the massive fenders of the Z.Post Pics when she's done!!
s13sr20chris
PalmerWMD wrote:Under what condtions?
idle and stock. dont know why. i see it almost every day. usually cyl 2. maybe its our fuel?
350zQ45a
Car: 350Z, Q45A
It sure does tuck nicely! My mechanic thought no way it would fit, then I told him to jack the car up and he was shocked how much room there is under there.. I think Nissan knew we wanted some big fat rims on the Z!
Pics tomorrow!
Return to “350z / 370z Discussion”
