Wheel fitment for 2006 infiniti M35
lovinmym
Car: Infiniti M35
Gotcha , yea I've done the arms on other cars that I've owned. That's the best way to go but as you said it ain't cheap.
06M4.5
Car: 2006 M45
It's best to install them at the same time your installing the coilovers. The coilovers springs don't have the same gap as the oem springs, meaning the bolts that hold the camber arm will not come out while the coilover is installed on the car. :frown:
Same problem with the camber bolts, ask me how I know
06M4.5
Car: 2006 M45
lovinmym wrote:Gotcha , yea I've done the arms on other cars that I've owned. That's the best way to go but as you said it ain't cheap.
like this:
http://www.ebay.com/itm/Eibach-Springs- ... da&vxp=mtr
Bravoval
Car: M35 Sport.
:chuckle:
Bro I just put these Stance SC5's on my o6t m35 sport here the are the pics. I have 20/10 all around with no problems whats so ever. Im running 245/35/20 toyo in the fron and 275/230/20 faulkens in the back look at the pics i jutst recently did this. :yesnod :yesnod :yesnod :yesnod :yesnod :mike
http://www.flickr.com/photos/bravoval/
lovinmym wrote:Greetings Nico Club,
I am in need of help/suggestions for fitting 20's on my infiniti M35. I have read many forums and have received some great information but nothing that convinces me on the best wheel size for my model car.
The plan is to lower the car with coilovers on Vossen CV3's. I definitely would like the flushed look (not looking to tuck as that would involve rolling fenders). I also am trying to avoid rubbing of any sort as this is a daily driver. On the other hand I do want a staggered look.
I have been given two suggestions - Either go with 20x9 front and 20x10.5 (which I was later told would stick out at the back too much) or go with 20x9's all around. I don't know how the 20x9's would look all around with these wheels as I feel I would lose the "staggered" look.
Any ideas?????? :confused:
P.S.Pics would also be great with suggestions
lovinmym
Car: Infiniti M35
06M4.5 wrote:I installed camber bolts for the front of my M45 when I went with the H-Tech springs. Alignment was in spec, thanks to the bolts.
But now I have the D2 Racing coilovers and would like sometime this spring to install the front camber arms being that the car is so low.
I see what your saying.
I need some help with my Ksports kontrol pro coilovers that I just installed last week. This isnt the first time I have installed coilovers on a vehicle and im bouncing in my seat every time I hit a bump. :gotme Ive been messing with the settings...going from full hard in back and front to halfway back and front and now half way back and full soft in front. The last setting is somewhat better but I would think the harder the setting the less play the spring would have.
The pain is that everytime I need to change the rear setting, I have to go to the shop for them to jack up the car and pull down the entire strut/coilover unit just for me to adjust it as there is no other way to get to the top. How are your D2's? Did you have similar issues initially? what settings are you running :confused:
lovinmym
Car: Infiniti M35
Bravoval wrote::chuckle:
Thanks for the pics brotha! I ended up going with my first choice, Vossen Cv3's. Im still trying to figure out how to get pics on this thing
06M4.5
Car: 2006 M45
Tinypic is easy
lovinmym
Car: Infiniti M35
06M4.5 wrote:Tinypic is easy
Ill check it out, did you see my post to you?
lovinmym
Car: Infiniti M35
:gotme
06M4.5
Car: 2006 M45
Very nice! Looks really good :cool:
lovinmym
Car: Infiniti M35
06M4.5 wrote:Very nice! Looks really good :cool:
Thanks Brotha :mike ......ended up adjusting the k sports all the way soft in the rear which is riding much better now.
White-Rush
Car: 06 M35S - Sold
11 M37S - Ran hard and sold
16 Q70S
Nice setup... :werd:
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
I like. What are the specs on the wheels?
lovinmym
Car: Infiniti M35
DoN_BLaZe34 wrote:I like. What are the specs on the wheels?
:dblthumb:
245/30/20 fr
275/30/20 rear
donnieb83
Car: 2007 M45S
Wow....very nice! Do you think 275/35/20 in the rear is possible?
InfinM3506
Car: 06 Infiniti M35 Luxury Edition, Journey Package, Tech Package, Burnt Orange Leather. Eibach Pro Springs, 20" Vossen CV3 20x9 255/30/20. 20X10.5 285/25/20. 08 Front Infiniti Sport Changeout.
295/30/20 would be possible if he has the 20x10.5 rears on his car like mine.
06M4.5
Car: 2006 M45
That 295/30/20 tire is big bucks $$$
InfinM3506
I got a pretty good hook up on my wheels and tires. I only went 285/25/20 cause i thought i would have issues with the 20x10.5 rear wheels. But next time i will be getting 295/30/20
06M4.5
Car: 2006 M45
InfinM3506 wrote:I got a pretty good hook up on my wheels and tires. I only went 285/25/20 cause i thought i would have issues with the 20x10.5 rear wheels. But next time i will be getting 295/30/20
it may rub but camber is your friend but in the long run your tires will wear faster.
lovinmym
Car: Infiniti M35
Anyone have issues with K-sport coilovers as far as the rear being too bouncy? Even after I adjusted it, it still is way too bouncy based on my past experience with lowering cars.
I have looked at other coilover applications and some come with the strut and coil in one (like the ksport) where others come with the strut and a seperate coil to replace the one there as seen in this photo
http://www.importtuner.com/tech/impp_12 ... to_06.html
Right now it seems to me that I have 4 sets of coils on the rear....the one that came on the ksport unit and the stock one to the right and left of the rear wheels.
Any suggestions????
06M4.5
Car: 2006 M45
PM sent
Best to go with true coilovers
D2's are different as they have 36way adjustments
lovinmym
Car: Infiniti M35
06M4.5 wrote:PM sent
Not sure if you read my entire post. I currently have K-sport coilovers on the car which are true coilovers. Just trying to determine if the other springs I see on the car need to be replaced also. The other spring I am talking about is shown in the link below. Looks like these guys replaced the coils and the strut. I do understand that with K-sport or D2 the strut and coils are in one but again there is another coil that comes on the M
http://www.importtuner.com/tech/impp_12 ... to_08.html
06M4.5
Car: 2006 M45
you must remove the oem spring
