mJacek84 wrote:When I bought my Maxima 2003 SE it had around 117k right now I have around 123k and make around 150M on one tank. I usually tank 15-16 gallons of gas so if I count it is around 9-10 MPG in a city. It looks peaty bad. Maybe I should go to the Nissan or any other auto repairing shop to check if I have everything ok? I am not good in a mechanic of the car so if any body could tell me what can I do to improve my mileage it would be grat!
PS: This Y-Pipe where I have to go to instal it in the car?
Modified by mJacek84 at 7:39 PM 4/2/2008
Any Auto shop should be able to install it yourself, but it's soooo much more fun doing it yourself
things i've done to help mileage:1. 44k BG Fuel system/Engine cleaner(purchased at Nissan Dealer) It runs smoother now!!2. Did 3 transmission drains in 2 days...then filled will Royal Purple Sythetic transmission Oil.3. Tire pressure was LOW, filled to Performance Tire spec of 40psi.4. Oil change w/ Mobile One 5w30 Full Sythetic and Lucas Oil Sythetic Stablizer.5. wax the car...no really...well it helps in the wind tunnel for NASCAR, so why not 6. carry less junk in the trunk.7. clean Stillen Filter
Need to do:1. R&R Fuel filter2. remove Stillen muffler, then purchase and install Cattman Y-pipe, mid-pipe, high flow cat, and muffler.3. remove Stillen Short ram Intake(WAI), then Install Cattman CAI4. Install CF hood and trunk deck for a slight weight reduction.
Modified by lightsout at 2:19 AM 4/9/2008
