if you take out the plastic fender liners, you can go as low as you want, depending on offset.TRAV95240SX wrote:whats the most i can drop it with 18"s ?i just dont like the 4x4 look after i got my 18"s on is 2" to low and should i go with 1.8" or 1.5" ?
Just go to cardomain.com or search around and see what others are using. You can compare your wheel offset and size specs to theirs and be able to make an educated guess. Or you could always go as low as you want and if it's too low sell the springs or trade for different ones.TRAV95240SX wrote:whats the most i can drop it with 18"s ?i just dont like the 4x4 look after i got my 18"s on is 2" to low and should i go with 1.8" or 1.5" ?
oreroc263 wrote:Just go to cardomain.com or search around and see what others are using. You can compare your wheel offset and size specs to theirs and be able to make an educated guess. Or you could always go as low as you want and if it's too low sell the springs or trade for different ones.
