whats the max width of the rim can we run ?
kermit the guy
Car: 2008 infinity M35 Sport
whats the widest rim that we can run up front on the M's and what offset without moddin the fenders? just wondering
07sportm35
Car: 2007 Infiniti M35 Sport
I would estimate about 10.5" with a +50 offset.
I (just for a few miles) ran a 10" wheel with a offset of +43 without any issues.
It looks really cool, but everything else is a negative...
kermit the guy
kool thanks man
bbs350z
Car: 350z built tt
350z st track whore
m35x daily
evo 8- 30r sold
im at 9" with +15 offset on an x. ill be giving it more width come summer time
mr_luv
Cool cant wait too see more of this, I am thinking 20x10 +30 with pull and roll or 20x10 +40 with pull and roll...
RM450GT
Car: 06 M45
i just ordered 19x10 +15... should be here in couple weeks
jjcuff1
I have a M35 and out cars have odd offset front to back. Ultimately unless I split up rim sets which most places wouldn't do I just had to custom order my rims. I went with 20x9.5-45 on all 4 looks perfect
Lexani CVX44
TDot
Car: 2008 M35X, Lakeshore Slate/Tan
07sportm35 wrote:It looks really cool, but everything else is a negative...
What exactly were the negatives? Could you give details please?
jjcuff1 wrote:I went with 20x9.5-45 on all 4 looks perfect
Looks perfect, but what's your experience driving with the fronts? Do you have more pics showing how it's poking out?
Will 19X10 and 38 offset fit on the front? ...no poking out and full turn(no mod)? The only reason I want something this big on the front is because the rear comes with deep concave and the front does not look symmetrical to the back, so I want to put the rear wheels on the front as well...as long as it doesn't degrade the ride that much; although I can't really understand how a wide wheel will degrade as long as it doesn't rub.
AZM45S
Car: 2006 Black M45 Sport
I currently run a 20x10 +38 all the way around with no rubbing and full turn. They do poke a little though.
06M4.5
Car: 2006 M45
AZM45S wrote:I currently run a 20x10 +38 all the way around with no rubbing and full turn. They do poke a little though.
What size tires are you running?
let see some pics.
AZM45S
I am running 275/30/20s.
Keep in mind that the second picture is on the lift with the suspension hanging. They tuck in a bit more when the suspension is loaded.
06M4.5
Car: 2006 M45
If the front sticks out you can get the front 2 wheels milled from 38mm to 42mm.
I did this to the rear of my car so that I could run the 285/30 without rubbing.
any side pics of the front, I would like to see how much they stick out.
george926
Car: M35
It really depend on what suspension you are running too.
I am running 9.5 with +24.
and 10.5 with +29
I am running air BTW. If you are thinking about doing air, my rear set up is the closest you can get without any mods..
mexillis
Car: M45s
The widest I've seen is 20x11f and 20x12r, idk the offsets though.
06M4.5
Car: 2006 M45
kermit the guy wrote:whats the widest rim that we can run up front on the M's and what offset without moddin the fenders? just wondering
without modding fenders
george926
Car: M35
Yup!
06M4.5
Car: 2006 M45
lots of camber too
AZM45S
Here are a couple more pics.
Front:
Rear:
Full side:
06M4.5
Car: 2006 M45
Thanks for the pics. Front looks nice with the fat lip. :dblthumb:
But the wheels just stick out too much for me. I like to have my wheels tuck. My rear wheels are flush with the fender lip after I got them millled (no camber). No rubbing even with the 285/30
mr_luv
Just ordered 20x8.5 +20 / 20x10 +25 switching to 20x10 +25 tomorrow up front.
Car is a X lowered on eibachs.
Available offsets are 20x8.5 20/35 & 20x10 25/40.
anyone ever mix and match those offsets on there cars front and rear?
06M4.5
Car: 2006 M45
Are you pulling your fenders or doing body work?
Because with the #'s you posted the wheels will stick out. :ohno:
YMm45
Car: m45 s
I ran a 20x10 +25 off set no issues no rubbing before my body work
06M4.5
Car: 2006 M45
YMm45 wrote:I ran a 20x10 +25 off set no issues no rubbing before my body work
Did they stick out? Did you drive the car with 4 people in it?
Because looking at your avatar you have lots of camber front & back. Maybe body work, camber & small tires.
The question here is how wide without any work done to the car.
20x10 et25 wheels should stick out a good 1/2"- 3/4" or more.
mr_luv
Any photos with your 20x10 setup? I am getting weary of the 20x10 +25 and may just get +40 and run spacers if I decide to push the envelope.
mexillis
Car: M45s
Depends on how stretched of a tire you want. David was able to put on his rear wheel up front with no issues.
mr_luv
Im not looking to do much of any stretching i want a near stock fitment with some camber and flush fit and from what i have seen the way to go is 40 but I see plenty people go with +25 with no issue. My idea of +40 is I can just plus spacers if I want to push it out.
mexillis wrote:Depends on how stretched of a tire you want. David was able to put on his rear wheel up front with no issues.
06M4.5
Car: 2006 M45
What wheels are you ordering?
mexillis
Car: M45s
06M4.5 wrote:... the wheels just stick out too much for me. I like to have my wheels tuck.....
I bet if he was lowered they would tuck.
06M4.5
Car: 2006 M45
I'm lowered on 20x10 42et and the wheel is even with the fender.
Adding 17mm will only make it stick out.
Maybe his type of wheel has a low disk but it's still a 25et.
YMm45
Car: m45 s
My avatar is after all of my body work and yes there was camber at that time after I switched my setup and went to a 20x10 with 0 offset. You can run a 20x10 with a 20 offset with no issues with four people in the car and that was when I was lowered on eibach springs had no issues and there was no camber and I ran a 255/30/20 for a tire
