texasoil »
https://forums.nicoclub.com/texasoil-u1000.html
Wed Dec 05, 2007 11:01 am
Qship (active) at Texas International Speedway! 2:51 PM 12/5/2007
I took my very stock 94 Q45a up to a weekend of high performance Driver Education (sponsored by Porsche Club of Hou ,Dallas, Austin) . The 2.9 mile course has 15 turns, longest straight about 1/2 mile, 3 other much shorter straights. The ONLY mod from pure stock is a strut tower brace.
Front brake pads are Bendix ceramic and the rears were also supposed to be that (most likely were not.) Tires 225x60-15 Fusion M&S (selected some time ago for wet street traction (AA) and hot freeway durability (temp rating A).
Brakes could easily bring tires to breakaway and never faded until rear linings ran out last lap of 4th run (I was pushing real hard-either max braking or max throttle almost all the time. The final lap finish of metal to metal ruined rear rotors of course. B4 starting that track session, the pads looked OK and good for at least 2 more sessions.On examination, it was obvious from the pad backing they were different that fronts and lining simply evaporated.
Front pads had 45K miles on them already!, still with 3/4 depth at start, rears same condition--and fronts STILL are well over 50%, with 6 hard sessions +45K miles!! Rotors are pristine also.
I was able to out run many of the Porsche's on the straights--but they generally had more cornering ability of course- with real wide, low profile gummy tires, track brakes and springs (those guys were SERIOUS-I just wanted training in high speed manuvering ,etc)
Was able to keep tires at breakaway on curves easily, holding my own with many on all but sharpest turns. Had one experience of real bad under-steer cresting a hill and failed to tap brakes to set the front end down B4 turning the wheel. Over-steer was easy to modulate with throttle. Wish I could 'hold' the transmission in a gear with no overdrive in/out lag. sometimes upset car with surge of 'go-fast' in middle of corners as throttle mashed to exit the turn and transmission computer backed out torque for shifting and then power returned with a surge on computer release. The 'sag-shove' was annoying.- I want to get rid of the 'sag' portion.
I was a great experience--coming off the front straight at 125 down onto the road course, hauling speed down ASAP then left,left, exiting at 55, short straight up to 85, brake brake 90 deg hard right, short straight up to 85, brake to 55, hard right, another short straight, sweeping left at 85, brake hard to 50, hard descending left (bad understeer here once- left the track), medium straight up to 95, steep banked sweeping left (after tap of brakes, hard braking to 45,sharp left, descending hard right, short straight to 75, brake hard , into a decreasing radius flat right 180 deg (43 mph) right into hard left onto 2 nd longest straight up to 95, medium left up-slope blindly into hard braking to 45,immediate hard left,right, left combo, accelerating at max onto long banked front straight up to 125 or so. WHew--2.9 miles in ??
Next time it is with wide sticky 16" gummmy-bears and metal-matrix pads, sway bar end links tightened up hard, and active computer tweaked if I can figure out how.
Rode several lap with my instructor in his nearly stock BMW M-3--awesome cornering forces.
The 'active' eliminates LOTS of body roll and all dive/squat, so it takes some re-learning from a 'standard' sedan.
Texasoilactivesuspensionsystems.com
