Or is there an option/feature that was removed and you would like to see it brought back?
The sunshade will slide or extend (My wife brought that to my attention, she has the same type on the Rogue)pedsemdoc wrote:1. I miss the independent sliding middle arm rest console top from my '06 M45
2. The second smaller sunshade for the front windshield, when you're using the main one to block glare from the side (again, had that on my M45!!)
3. Heads up display for speedo/tach and navigation
Bingo..sometimes it is those little things that sway you. Because I had the rear power shade in a previously owned Maxima, I looked for the option in the current M I have now.EdBwoy wrote:...As a non-Q70-owning Infiniti lover, it's the little things that sway me.
Not sure about the Q70S, but the Q70L loaner I drove while I was having my timing chains replaced had the rear door closers as well as the trunk closer.reggiebrown40 wrote:I'm in a loaner Q70S AWD right now and they've removed the suede headliner and replaced it with a mesh type material (or maybe it's because it's sport?) the stitching"Infiniti" has been removed from the seats. I can't double press the start button on a running car to have it continue to power the radio while the car engine shuts off. Rear sunshade that goes down in reverse but doesn't come up when you go back into drive is a huge annoyance too. Car has auto trunk closer but nothing for the doors. That makes no sense. Infiniti's cost cutting measures make me scratch my head.
I believe the twin turbo is the future. I believe the v6 will eventually be phased out.beachbum718 wrote:Twin turbo...and entire revamp of body that looks nothing like the q50.i hate the current q70.looks like a stretched out q50.
Point 1 is spot on Hyundai does do that!!Larz wrote:1) continue the rear windscreen shade, but add rear door shades as well. Even Hyundai does that !
2) put the logo back on the seats - front AND rear
3) on the L models, add more than cup holders in the arm rest - at lest recliners. Air con controls, USB and power outlets
and ....... most important ......... make a bloody panoramic roof like the rest of the car makers have done for years !...
Yeah I'm with you on the TT engine. I bet that does happen with the new VR30 3.0 engine Infiniti is dropping in the Q50's. I however couldnt disagree more about the look of the newer Q70's. The evil eye aggressive front end and great booty make the Q70 a stunner in my opinion (I may be a little biasedbeachbum718 wrote:Twin turbo...and entire revamp of body that looks nothing like the q50.i hate the current q70.looks like a stretched out q50.
Wasn't on the Q70S AWD loaner I jut had. Cost cutting.....M37xfan wrote:Is the forest air option gone?
reggiebrown40 wrote:Wasn't on the Q70S AWD loaner I jut had. Cost cutting.....M37xfan wrote:Is the forest air option gone?
True as far as performance but I disagree with you as far as the other options being just minor tweaks.wideopn11 wrote:Make a TRUE "S" model (think Jaguar) with forced induction either turbo or super, a real sport suspension and a man pedal option. Slapping a "S" badge on a car for a few minor tweaks that don't make it faster than the stock version really grinds my gears.
Or reserve the "S" badge for V8 version only with additional performance enhancements.
I think the Q50 is going this direction with the Red Sport having 100 more horses than the normal Q50S.
