CaptainHenreh wrote:These "who would win" questions are really easy.
Let's take a 1999 Ford Mustang V6.
Weight: 3069 Lbs.Horsepower:190.Power to weight Ratio:1hp:16lbs
Now, your S13 Weight: Approximately 2700 lbs.Horsepower: 205PTW: 1:13
So, because you have a better power to weight ratio, you'll probably win. Um, you'll win bad. You'll go to jail for assault.
(On a Sidenote, maxpower, a KA24DE has only 155 horsepower.That's a PTW of 1:17.5 which is worse than the Mustang. Now, while there might be other factors involved, alot of them having to do with driver skill, I'd hardly say that a KA24DE will 'own' a V6 mustang. It'd be close.)
So let's move into GT's. We've already determined your PTW to be 1:13, although admittedly it may be a little higher. (You don't still have your stock KA exhaust do you?)
2000 Ford Mustang GT (4.6 Litre) (Couldn't find the weight for a 99)
Weight: 3242 LbsHorsepower: a whopping 260 horsepower.PTW: 1:12.4
This time, it's close. Alot of factors come into play. He's got alot of low-end torque, he'll probably jump you at the beginning. But once your turbo spools, you ought to pull on him, and maybe come out on top at the very end, owing to your higher redline. Maybe. It would be close, I think. Crank up the boost a couple of pounds and you'll have a better safety margin.
2000 Cobra SVT
Weight: 3560 lbsHorsepower: 320PTW: 1:11
Prepare to have your *** handed to you in peices.
It's an easy formula, and while not with 100% "this is what will happen" predictability, it ought to give you a good idea of what would happen in a straight line.
Sorry, I was bored this morning.
I would just like to add that horespower figures shouldn't really be used to determine the winner, i know what you are saying though, and teh PTW is a pretty good idea. But, for one the horespower figure is at a certain rpm, so it would extremely help to know the whole powerband to get a more accurate prodiction. Also there are many other factors like tires, suspension set up, aerodynamics, gearing, driver skill, etc. so all though this does help some what it should not neccisarily detirmine the winner. not that i'm saying anything bad about your post or your idea : )
