WHAT WHEELS WILL FIT MY ALTIMA?! Will it fit? Rub?
Nicky Altima
Car: 2008 Nissan Altima
Hi, I will be getting some wheels for my 2.5 SL Altima Sedan next week..
SSR GT318x8"5x114.348 offset
Will this work on the sedan?
ESP
Car: 2008 SexyBlack A/C
48mm offset? That's higher than the stock 45mm, so your wheels will be tucked inside just a little bit more than stock. If possible, try and find something between 35mm and 45mm for the best looking stance. 48mm should work though...
Nicky Altima
ESP wrote:48mm offset? That's higher than the stock 45mm, so your wheels will be tucked inside just a little bit more than stock. If possible, try and find something between 35mm and 45mm for the best looking stance. 48mm should work though...
Found a good deal that I couldn't resist..but it will not cause any problem though, right? I will be running 245/45/18 with these..
jojeda89
i neen some help i want to get some 20s on my 02 3.5se but i want to know if they will rub
beeristasty
Car: 07 Altima 3.5 SE
The rims he is looking at are 1 inch wider than the stock 16x7's. Assuming the same offset, this will make his wheels approximately 13mm wider on each side. Taking into account the 48mm offset and the wheels will be pushed out 10mm further than stock.
Mackan
Hey guys,
To get to the point. My car IS dropped and I got some new rims: 19*8.5 with a +45 offset. What tires should I be running for it not to rub?
joshyth
Car: 2008 Altima 2.5SL
so i got some Altima SE-R rim couple day ago, and i am wondering if 234/45/18 tire will work for them?
Silver_Phantom
Car: 2007 Altima 3.5SE
I am looking into getting some new wheels and I was curious about fitament issues of them.
I have an Eibach Pro Kit drop and the Rays G Games I want are:19x9.5 all around with a +40 offset. I would use a 245/40 tire with them
Would these set up work fine?
mcheddadi
Car: R8
Yes, you might get a TINY inner front fender roll but thats ok. There is like a 1cm inner fender lip that will get flattened but that's impossible to notice
Silver_Phantom
this will happen naturally after riding on the wheels or I have to get this done before putting them on?
scanlessfool
Car: 94 Honda CD7
Going to test fit some 20x8.5 +35 tomorrow. I already know I'm going to either have to go with a lower offset or wider rim with slightly higher offset.
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
scanlessfool wrote:Going to test fit some 20x8.5 +35 tomorrow. I already know I'm going to either have to go with a lower offset or wider rim with slightly higher offset.
Put 245/35/20s on it and you should be fine.
scanlessfool
Car: 94 Honda CD7
Ya, I know. Thanks. But it's such a weak width and eh offset. I would much rather go 9's
sfalx415
Car: 09 Altima Coupe 3.5SE 6M
hey longbeach, what set up do you have with your 20s?
altitobby
Car: nissan altima ser 2005
hi i have a altima with maxima 18/7.5 wheels on and i want to know if i could put 245 /40/18 on them thanks
altitobby
LongBeachCoupe wrote:Ok guys i get a decent amount of emails asking me basic fitment questions on what wheel sizes will fit our Altimas.
First, the bolt pattern is 5x114.3 (some places may call it 5x114, dont get nervous)
Lug Nut size is 12 x 1.25 (make sure to pick up a thin wall socket)
Something that is very important is staying close to the stock diameter of the entire tire/wheel combination.
Check this site out. http://www.miata.net/garage/tirecalc.html Once you find the wheel you like, use that to find the right tire size.
3.5 Stock Information 17x7.5 26.3" Diameter +45 offset ---> 215 / 55/ 17. This means, the tire is 215mm wide, the side wall is 55% of the width of the tire (215 x .55 = 11.825cm) ... 11.825cm / 2.54cm per inch = 4.655 inches for each side wall. 4.655 x 2 (two sidewalls)= 9.31 inches + 17 inches (size of wheel) is 26.31 inches. (incase you wanted the math)
So for a 20" rim, you could get a 225, 235, 245, or 255 cm wide tire, however, note that when you go wider with the tire, the smaller the sidewall is gonna be in order to fit close to factory specs. And the smaller the sidewall, the more uncomfortable the ride will be.
For 20" rims, here are some possible tires to stay close to factory specs
225/30/20 = 25.31225/35/20 = 26.2225/40/20 = 27.08
235/30/20 = 25.55235/35/20 = 26.47235/40/20 = 27.4
245/30/20 = 25.78245/35/20 = 26.75245/40/20 = 27.71
The ones in bold are the closest to factory specs. You can do the same equation above for 18 and 19" rims
Some specs on 19s19x8:225/40/19 = 26.1"235/40/19 = 26.4"
19x8.5:235/40/19 = 26.4"
And some on 18s18x8 on 235/45/18 will get you to EXACT factory specs (26.3") but 225/45/18 (26.0") is damn close enough and tires are a lot cheaper.
This info is for the 08 Altima Coupe and is a work in progress... Chime in with your fitment/offset/drop
ALL Stock Infiniti G wheels will fit.
Ovrbst had NO RUBS with a staggered 19x9x5 fronts and 19x10.5 rear setup (no drop, that would cause issues)
I will be "sweeping up" the thread to make it very easy to understand.
hi i have 18/7.5 maxima wheels on my altima will 245 40 18 tires fit on them
altitobby
hi can anybody tell me if 245/40/18 fit on a 7.5 maxima wheel for an altima se 2005 thanks
tmsxl
I'm looking at Enkei's J10 wheels in 18 inches. Says they have a 38mm offset. What tire size would be best? America's tire recommends 225/45/18 or 245/45/18. If I decide to drop it later on, will I have any rubbing issues with either? Which will give the more "low profile" look. Thanks!
Hapa180
Car: 1990 240sx 2008 Altima
XenonSE-R wrote:I'm about to repeat the same questions as everyone else, so I'll be quick. I'm new to this game as well.
- I want to do an Eibach drop. 19x8 5Zigen Hyper 5zr wheels, 235/40/19 tires.
Offset options are as follows - 45, 38, 33, 25, or 23mm
Which offset would be optimal for putting the wheels just shy of flush with the fender? I want ZERO rubbing so I'm trying to do all my hw. Thanks!
on my 08' im running 19x8.5 +35 axis mods with a 245/35 on cut eibachs i have absolutly no rubbing. i will be switching to some ArkDesign R8's 8.5+30 very soon....
so if you buying 8"s then you could run a +25 or +23 and theyd be flush.
mcsniper703
Car: 2009 Altima Base Black
I need help with wheel sets up. I have base model 2009 sedan altima.The wheels size I like to do is 18x8.5 but what the lowest offset is possible to fit in the wheel of front and rear? The wheels would be Work VS-XX thanks.
Ranga14
Car: Boosted 08 Altima Coupe 3.5
I'm getting some 18x8 wheels and considering the following;
245/40-18, it says 3.86 section height / 9.65 width$159/wheel @ Discount Tire
245/45-18, it says 4.34 section height / 9.65 width$171/wheel @ Discount Tire
Should I go with the more expensive option considering the tire might last longer and I'd like to have more rubber... I was afraid to do that because I have EiBachs and thought it might rub? Unsure here.
alma_cpe8
Car: 2008 Black Altima Coupe
I need a little input on what size tires to go with to best fit my rims. I'm going with a set of 18" ADR Phantoms. The have a width of 7.5 and an offset of 42. Any suggestion on proper tire size and should i opt for hub centric rings as well or?
White_SR
Car: 2010 Altima Coupe 3.5 SR (CVT)
Deleted, see next post instead
Modified by White_SR at 9:26 PM 2/21/2010
White_SR
Got another question lol
19x9.5 +38 offset rims
255/35-19 tires
The Wheelmaster calculator says it's 0.1" closer to suspension/brakes, wheelwells 100% clear , speedometer 1.2% slower
Lookin for feedback from either opinion or experience. Thanks
mcsniper703
Hi, I am wondering if you can assist me with wheel set up?I have 2009 altima sedan base model. I understand most factory offset is +38.
I am wondering if the 18x8.5 offset +30 and tire set up is 235/35-18.The Package will stick out 18 mm (0.7'') farther. I haven't seen altima with +30offset but that why I asked you if you think that is very possible to do this.I am wondering how many mm will clear front and rear if the fender is rolland pull a decent flare?
Thanks..
iluvnissan
Car: 2008 nissan 2.5 altima coupe
dude i am runnin my altima on 20" wheels and my ride is comfortable
mcsniper703
what width of the wheel and offset? you have pic of it? is it on the sedan?
Coupeguy23
Car: 2006 G35 coupe sport
i want to know what kinda tires size will work with this set of wheels 18x7.5
jitu884
Hi there,I have the 04 maxima rims with tires that are245 45 18 on my 02 altima 3.5
they are rubbing alot
should i switch to 225/45 or 225/40?
thanks in advance!
Hapa180
ok sedan guys just did some test fitting today!
i threw on some 19x8.5 +30 ARK design R8 wheels all around and fit almost perfect.
the front fit perfect....as for the rear......
amazingly i test fit a pair of 19x9.5 +40 ARKdesign R8 wheels with 255/35 in the rear and it fit PERFECT!!!! my car is lowered on eibach's but i cut them a half coil so its a little lower than usual. but the fit and it looked great!!!!!!!!!!!!!!!!!!!! sorry i didnt take any pics though. ill get some with the 8.5 +30 for you guys
