WHAT WHEELS WILL FIT MY ALTIMA?! Will it fit? Rub?
marlin29311
Car: 2008 Infiniti G35x
I have a quick question about offset...
Tire Rack shows that basically every wheel they offer will fit on the a/c, all with varying offsets. I wanted to get a 18" wheel with either an 8 or 8.5" width, but i don't really know what offset i should be getting with that - and they way everything on the 'net reads about offsets, it sounds like if you get the wrong one you will screw up the way the tire tread wears, the car drives, etc....
what kind of offset should you get for an 8" or 8.5" wheel?
mcheddadi
Car: R8
I've seen up to +38 , mine is +40 and stock is +45
maxentropy
Car: '08 Altima Coupe 3.5SE
So my final setup will be Konig Troubles 19x8 5x114.3 with an offset of 30 and Kuhmo Ecsta Lx Platinum All Seasons in 245/40R19.
Tire Size:New Tire Size / Radius in mm / mm difference in height off the ground from stock245/40R19 / 339.09 mm / +5.08 mm difference / +1.5%
Wheel offset: Clearance from stut housing to the inside of the wheel will be 9mm more but the outside edge of the wheel will extend an extra 21mm...
Does anyone have a setup like this? Is a +30 offset with 19x8s going to have any issues (rubbing/performance/etc)?
I will be calling Stillen today to ask for my hubcentric rings. I called Konig and they told me to definitely get them if I want a smoother ride at high speeds. OEM spec is 66.1 mm and the Konig wheels hub bore size is 73mm, so like Loop stated, I will need a hubcentric ring. Konig assured me they do not make, nor ship hubcentric rings with their wheels- it is the sellers part to do so (tirerack.com, Stillen, etc). So, I'm off to call Stillen. They only cost like $10.
Any info or insight on my setup would be much appreciated fellas!
Modified by maxentropy at 2:25 PM 7/22/2008
mcheddadi
Car: R8
It's going to rock! make sure to get the correct lug size and hubrings!
and don't forget to get pics
maxentropy
mcheddadi wrote:It's going to rock! make sure to get the correct lug size and hubrings!
Will do-- my OEM lugs should be good if my new wheels are 5x114.3 right?
mcheddadi
Car: R8
depends if the lug base is flat or if its like a bullet on your new rim. I had to change my lugs.
beeristasty
Car: 07 Altima 3.5 SE
I'd recommend getting some locking tuner lugs. Won't prevent theft, but will help deter it. Protect the investment!
felv8
Car: Altima Coupe 3.5se Code Red Metallic
Is 19x8.5 with a 35mm offset on an eibach drop too much, in terms of rubbing/fitment? based the original post, I would go with either P235/40/19 or P245/40/19 (which tire would provide most comfort?)
thanks!!
maxentropy
beeristasty wrote:I'd recommend getting some locking tuner lugs. Won't prevent theft, but will help deter it. Protect the investment!
Hell yeah. I have one on each wheel-- will transfer from my current stockers to the new wheels as soon as my tires come! (If the lugs will fit anyway) -- Everything is a learning experience!
Just ordered Hubcentric Rings (Inside Diameter 66.1mm Outside Diameter 73mm) instead of screwing around with Stillen-- I'm sure they don't have the rings due to the fact this was a special deal. Anyway here is where I got my hubcentric rings:http://www.sfxperformance.com/parts/TOPC736610.htmCost me $15 plus shipping - total came to $22.
ESP
Car: 2008 SexyBlack A/C
Max,Aren't you getting the Troubles? I didn't think hubcentric rings were needed with them (or the Coupe)... Perhaps I'm wrong...I've been drinky-drinky tonight so I could be off my rocker...
maxentropy
ESP wrote:Max,Aren't you getting the Troubles? I didn't think hubcentric rings were needed with them (or the Coupe)... Perhaps I'm wrong...I've been drinky-drinky tonight so I could be off my rocker...
The customer services folks at both KONIG and tirerack stated you don't necessarily need them since the lugnuts keep the wheel in place very well, however at high speeds 70+ mph, you may feel vibration. I figured I'll throw $22 at some hubcentric rings if there is even the possibility of it helping maintain some smoothness of the ride (whatever smoothness is left after getting 19 wheels and huge mofo tires ). See below for Loop's explanation. This has been confirmed by wheel and tire professionals. Again, not necessary, but possibly important. However I did hear from many people on these forums that they felt no vibrations from their wheels/tires without the hubcentric rings and you may be fine without them, but the bottom line is there is a gap between OEM and KONIG wheel hub bore size. You can leave the gap as is and hope the lugnuts keep the wheels steady or you can fill it with hubcentric rings which can be bought for $22 for all 4... I figure better safe than sorry.
What I am really worried about is rubbing with my offset. If it works, I'm gonna look hella aggressive
Loop's post explaining hubcentric rings from earlier--
Loop wrote:The more important one is getting hubcentric rings if the inner hub bore of your wheel doesn't match to OEM spec, which is 66.1 mm. In your case, the Konig wheels hub bore size is 73mm, which means you will need hubcentric rings. Whoever you bought the wheels from should of supplied you with them.
mcheddadi
Car: R8
I felt vibration at 60mph so I unscrewed the wheels and put the hubrings on early. now it's butter smooth
bigpapi1919
Car: 2008 Nissan Altima Coupe Black 2.5
i was looking at different rims and i really like this set of giovanna's but what would look and ride better 18's 19's or 20's? any ideas?
missmedude
Car: 2007 Altima
if i wanted 18x7 what offset would i need to make my wheels completely flush with my car?
Enzo24
Car: 2008 Nissan Altima 2.5 S
Hey guys,I've got an 08 Alt Cpe 2.5S.I'm looking to get 225/50/17 tires with wheels to match.I've checked out the tire calculator, it's well below the 3% tolerance.But the guy at the tire shop tells me its not recommended for my car.He's saying it may rub..?I'm also interested in using the Eibach springs.He says that will just aggrevate the problem of rubbing..?Any input on this?
Also, is there any tire size that is recommended by Nissan?Possibly putting the 3.5SE wheel/tire size on?Ideally I'd like to keep my car under warranty.Thanks in advance ppl.
mcheddadi
Car: R8
if its +3% you will rub if dropped with +40 and 255 but with 225 I'd doubt it will rub unless you got a crazy offset like +20 , if it's -3% you won't rub
LeGates
Ok super newbie here. I just got a 08 Altima and plan on putting 19" nismo rims on. I found a place online to purchase them and need some recommendations for tires, all season. Is there anything else I need like rings for spaces for whatever. I am planning on lowering later on.
azureblaze
Car: NISSAN ALTIMA 2.5S CVT
Pls tell me what's difference between 18x7 and 18x8 rims for tire 225/45/18? I'm gonna replace tire & rims to 18" with 40 offset. Nothing need to replace? like wheel spacer, rings etc...
mcheddadi
Car: R8
One is wider and the other is narrower.....Your tire will be squished more in one than the other lol. Now wasn't that simple
azureblaze
I'm gonna put 225/45/18 tire to 18x8 wheel.Problem is that wheel I look for is only have 47 offset.Original A/c comes 45 offset and some professionals said 47 is no problem at all. Is that right?What about 225/45/18 tire to 18x7 +40 offset, is it better?
Modified by azureblaze at 6:39 PM 8/27/2008
mcheddadi
Car: R8
azureblaze wrote:I'm gonna put 225/45/18 tire to 18x8 wheel.Problem is that wheel I look for is only have 47 offset.Original A/c comes 45 offset and some professionals said 47 is no problem at all. Is that right?What about 225/45/18 tire to 18x7 +40 offset, is it better?
depends on what you define as better. I'd go with the widest possible wheel and tires, with an offset arround +40 or +45.
or you can go with deep dish but you'll need a narrower wheel to fit it without rolling the fenders.
azureblaze
You mean 225/45/18 to 18x8 +47 offset is not working?
I have 3 choices for this wheel.
215/55/17 17x8 +40225/45/18 18x7 +40225/45/18 18x8 +47
Please advice me.Thanks!
beeristasty
azureblaze wrote:You mean 225/45/18 to 18x8 +47 offset is not working?
It will work. I'm running 245/45/18's on 18x8 +48 rims with no problems.
azureblaze
Thanks! by the way, did you put any hub ring adapter or spacer?someone told rub over +45 offset without it.
maxentropy
+45 offset with 245/40/18s are fine.. its when ya get to a +45 offset with 245/xx/19 or higher you run into issues. I personally have 245/40/19 and had some rear rubbing. I put my OEM springs to alleviate the issue for now. Still contemplating whether I leave them in for good or not... I kinda like the aggressive look of the lower front and higher rear. Plus, it keeps my wheels on the road.
Anyway, with 18s, you got room, when ya get to 19s I wouldn't go more than 240 or 235.
maxentropy
azureblaze wrote:Thanks! by the way, did you put any hub ring adapter or spacer?someone told rub over +45 offset without it.
Oh and definitely get cheap hubcentric rings if your new wheels dont match OEM spec. There are calculators online that will tell you what size OEM is and what size your new wheels are. The hubcentric rings minimize vibration during high speeds and I highly recommend them-- they are only $25 tops for all 4.
beeristasty
Isn't your rubbing due to your low offset (+30)? +45 would mean the wheel has more of a tuck (outer edge would be further into the wheel well and thus less likely for the tire to rub against the fender) assuming the tire width is reasonable.
Essentially, a 245/45/18 tire is the same diameter as a 245/40/19 tire. So judging by my experiences, nobody should come close to rubbing with a 245/40/19 or 245/45/18 tire when the rim's offset is around +45.
azureblaze
so what size of tire can be fit to 18x8 rim with +47 offset?
digitalbow
Car: 2003 Nissan Altima 3.5T
azureblaze wrote:so what size of tire can be fit to 18x8 rim with +47 offset?
I'd normally put 245 rubber on a 8" rim, but to maintain the overall diameter size as close to stock as possible, you might want to try a 235/45/18
OttawaCoupe
Car: Nissan Altima Coupe 2.5S
hey guys,
What about wheels that are 18x7.5 with (+45). Will it work? and what is my range in tires?
I know 7.5 is on the smaller side and with the (+45) my wheels will look a little "sunken" (can't be worse than stock), but those are the only 18's they make, and I really like the wheel.
Thanks for help!!!!
