What was done to your truck this weekend?
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Belltech spindles?
longtooth
Car: 89 d21 HB
Reverend D wrote:Belltech spindles?
Yep
Then when putting them in new front pads/ rotors/ ball joints and repack the wheel bearings.
demetrius
Car: 1995 nissan hardbody
in the process of relocating the battery...
...and debating wether or not to keep the power steering and a/c.
longtooth
Car: 89 d21 HB
demetrius wrote:in the process of relocating the battery...
I wish my truck had those features.
Rev_D21
Planning on doing a write up? I have a similar plan except it involves the spare tire.
Rev_D21
Cleaned the interior of my green 95. Also ordered a VDO Vision series oil PSI gauge since CB doesn't sell to people for orders less than $100. Also finished wiring the roof mounted spot lamps on my gray 96. While I was in there I swapped the gauge cluster to red LED bulbs. It looks pretty bad a**.
StephenG
Car: 93 Nissan Hardbody 2wd KA24E 5spd
87 Nissan 200sx CA20E 5spd
Reverend D wrote:Cleaned the interior of my green 95. Also ordered a VDO Vision series oil PSI gauge since CB doesn't sell to people for orders less than $100. Also finished wiring the roof mounted spot lamps on my gray 96. While I was in there I swapped the gauge cluster to red LED bulbs. It looks pretty bad a**.
Mind sending me a parts list for that red LED swap? I have zero knowledge of wiring LEDs... I'm a bit intimidated with the resistors thing.
longtooth
Car: 89 d21 HB
Thow some pics up!
Rev_D21
No real wiring needed, just pull out 5 194 bulbs and replace with 194 LED bulbs. To gain access to the cluster you have to remove the clam shell around the steering column, the lower dash and the black plastic piece surrounding the cluster. Take out the 4 screws holding the cluster to the dash, unplug the 4 connectors (they have locks on both sides so you have to squeeze them both at the same time) then locate the 5 194 bulbs holders. I'll get some pics tomorrow night, it raining right now.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Mounted a tow bar to mine. It's getting dragged up to Colorado for a week of wheeling this coming weekend.
PEZi
Desert Rat wrote:It's getting dragged up to Colorado for a week of wheeling this coming weekend.
where at? if its close enough we might be able to meet up at some point
pejsa s-13
Car: 91 HardBody, 85 720
ordered new coilovers for the rear, started at it for hours trying to figure out a game plan to straighten my frame, and started looking for a new welder.
Desert Rat
2017 Frontier 4.0
2008 Boulevard C90T
Going wheeling around Ouray-Siilverton-Teluride
longtooth
Car: 89 d21 HB
pejsa s-13 wrote:ordered new coilovers for the rear, started at it for hours trying to figure out a game plan to straighten my frame, and started looking for a new welder.
What happened to your frame?
jimschouster
Car: 1995 XE Std Cab
demetrius
for relocating the battery?
i guess i could, but i ran into a snag. the battery box i purchased won't fit behind the seat the way i want it to, so for now the battery is passenger floor. :facepalm:
when i get done, i'll write it up.
Rev_D21
pejsa s-13
abuse and sliding into crap, its twisted to the driverside bad!!! driver side rear is pushed down about 3.5 inches. im thinking its from the way the truck torques... clockwise
jimschouster
