What was done to your 240 today?
IKGamex
Car: s13
put on a 2.5" BRM exhaust
Seanzyyy
Car: 1990 240sx se coupe
walked past her on my way to my other car to go to class this morning.gave her a smile,been driving her the past few days(had been running like s***)
jgc731
Car: 93 240sx coupe
left her parked outside since i heard it was gonna rain so it needed a rinse, especially after some bird sh***ed on her yesterday....
diabeticon
Car: 1989 Nissan240sx
Did rear dusk brakes last night...the kind with the screw type piston....omfg what a biatch!!!!
Opey240sx
Car: 1995 Nissan 240sx SE
diabeticon wrote:Did rear dusk brakes last night...the kind with the screw type piston....omfg what a biatch!!!!
Needle nose pliers ftw on those, ez stuff. and always make sure the tabs on the pads line up the with the piston.
On my car, sub frame bushings, gas tank and all fuel hoses..got it back together and rides like a champ! finally did the bushings after 3 years of "Clunk"
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
I just use the little cube tool and a socket wrench, never been an issue...
pacotaco345
Car: 91 240SX coupe
I drove it about 100 miles and picked this up
crakin
Car: 1996 240sx s14, 2008 Chevrolet silverado crew cab,
2011 Suzuki gsxr 750
my driver side door wouldnt open from the inside when you lock it and shut the door the lock wouldn't pull the bar far enough to disengage the lock.
1.So i removed the door panel.2. took the handle/lock mechanism off. (black square with the handle and lock on it.) inside mechanism3. took the gray bar that hooks into the lock and found that over the years the motion it does, stretched the bar a bit at the offset closest to the handle (inside)4. I just bent the offset enough to take some length out but not so much that it effects the fitment.5. ta-da it worked like new.if you don't know what an offset is..it is two bends in a row that form a Z shape.Search itNow I need to see if I can tighten my window rail to see if it will stop rattling.
RB13240
Car: 93 240sx Hatch
Finished installing my interior, painted Z32 calipers, prepped the sub frame for painting, and of course gave her a big hug goodnight!
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Started scraping the SR's block... Head should be done tomorrow afternoon, and the ECU was finished with tuning today. Should have everything done in the next week or so!
Anyone got any tips to make removing the head gasket any easier? Or is a razor blade and some brake cleaner the only way to go?
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
You can wire wheel. Just make sure to clean up carefully.
mattblancarte
- Oil change- Tech de-brief- Cleaned garage and organized tools- Drove it down the street, scared some kids
Asia989
Car: 90 s13.4
threw her on the battery charger, played with my kouki headlights and messed with the h.i.d.s, and jus got back from picking my ecu up from enthalpy
S133P3R
Car: 1989 S13 240sx
i fell asleep on the 2nd bus of my 2 hour ride home from work and dreamt that i was driving my 240 on the streets -legally. DAMN!- i just missed my stop! fkn good for nothin 240!
Nismo121
Car: 96 Silvia
installed isis front tensiom rods & new brakes
speedeast
^Nice. Looks like you're due for some big brakes...
Timos240
Car: '95 240sx not quite stock,
Did a temporary fix on my header/down pipe gasket, fasten my amp control in a more accessible location, cleaned the interior, and drove it around town with the windows down and the music up.
boriquaS13
Car: 92 240sx
Installed front lip.......
Future_gohan
Car: 91 240sx, 91 vert
Gave her a bath<3
X abisai X
Car: 91 240sx coupe
got the hella vision plus
alloverdajoint
Car: 91 hatch sold
89 coupe sold
95 zenki daily
I brought Both of my girls today. A black 90hatch with 90k good transmission and no engine. And a red 92 with 110k great engine but bad gears. Picked them up for 700 and trailered them downtown. Felt goodd to be able to just sit in them and ponder about future plans.... Hmmmm! Been thinking about clean, low, wide, and simple.
thompsn
Car: '93 s13 coupe
Washed like 3 pounds of pollen off her.
Nis-240sx-san
Car: 1991 Nissan 240SX KA-T
Drilled out the spot welds on the battery tray, installed 1/4 of my interior.
EnjoiNismo
Car: 93 240sx
Let my girl take my car while im at work to let her dad put on new back tires
Asia989
Car: 90 s13.4
yesterday i broke the outside housing to the thermostat-replaced with sparetoday- mysterious antifreeze dripping down my front cover, jus ripped the water pump off and resealed .....maybe a bath today but i doubt it with al the pollen
Nismo775
Car: 92 240sx Fastback 5 spd./2010 Chevy Camaro 1LT
took out my blown suspension and installed some megan streets.
and installed my isis short shifter
bmr.S13
Car: 93 240sx hatch
bought (new to me) hood, sanded it down,wire wheeled all rust spots (only tiny ones), and layed some rystoleum on itisis short shifteroem 240sx carpet mats
today was a good day
rc1honda
Car: 1992 240 sx
2007 BMW 335xi
2008 Honda CBR1000RR
Installed GTR R32 driver and passenger seats today. Booya. Very supportive, can't wait to feel them under boost.
Demonspeed
Car: 1989 Nissan 240sx
'Accidentally' went drifting around the block since it was raining earlier..somehow it ended up fixing my fuel pump so no complaints
Modified by Demonspeed at 12:44 PM 4/5/2010
speedeast
Took out seats, dash, carpet, and remaining trim - more to come.
