Chaos the Xile wrote:1st off get the swap done. Most everyone here will agree with me. Run it for awhile and see how you like it, before you jump into a turbo upgrade
Carl H wrote:unless you have experience building these cars and motors just drop the motor in with a STOCK setup and go from there...its alot less of a pain in the *** to trouble shoot a stock setup than one that has been highly modded.
Chaos the Xile wrote:maybe a RB25 turbo or something newer but I would focus too much on a turbo upgrade so soon where there are other important parts that sould come first.
s14 2510’s wrote: The stock rb20 turbo is a turd. But it is nice to start the engine all stock first to make shure you are running correctly before you make upgrades. That way you know dont spend a week (F)ing aroung trying to find all the small problems when you go to tune for the new turbo ect....
Kamin wrote:just put the engine in, then have fun. dont worry about huge upgrades till after you learn how to drive the car. Dont take anything personally, im just giving advice.
Kansei240sx wrote:I dont drive a honda and never will, but i agree with Kamin in the highest reguards of what he said. Learn some more about the motor and how to properly drive a higher HP rwd car.
Bronze MFP wrote:this thread hurts my brain. get the STOCK swap done first. if you get that running right and reliably you will have tons of fun. after that, think about mods.
skillzilla wrote:Now, if you want to swap in a basically stock motor and do some supporting mods, thats a whole different ball game. It becomes tiresome when everyones first post in the RB forum caters around what turbo to buy or needing directions to a wiring write-up.
Chaos the Xile wrote:If you put the motor in with just the basics - FMIC, Fuel Pump, BOV, Intake, Exhaust, Cooiling Fans - You have a pretty kick as car from jumpstreet, then mod from there. Its the easiest and safest way to go!
CursedGTR wrote:Or you could take the smart way and make sure you have a functional vehicle before you modify it. A turbo isn't **** to change out, but a new motor is. I could care less either way and I am not in love with my suggestion but I have made quite a few costly mistakes that have ran me into the 10's of thousands over time.
mello88 wrote:I agree with the others regarding dropping the motor in relatively stock to begin with. If you do all the upgrades you want before even cranking it up and running for a bit; it probably won't work right out of the box and you'll have a difficult time sorting out which upgrade is causing which problem. But once it's operational the sky's the limit..
DriftingisLame wrote:I agree with the other dudes on the 'get the car running first' side of things. I'm not saying dont upgrade.. I'm just saying, see how you like the car's power and response on the stock turbo, and let that reflect on your choice of aftermarket turbo.
monkeyofdrift wrote:I say learn how to drive 1st before you do anything like a turbo upgrade, you'll kill yourself.
Chaos the Xile wrote: Learn to drive we don't want to see you or the car get hurt, it has happened.
AZhitman wrote: 450 hp in an S-chassis, unless you're incredibly experienced(*), is WAY more than you'll be able to handle.
Has nothing to do with gender, I say that to the guys here as well.
themadscientist wrote:Get used to the platform and how it behaves before doubling the power otherwise your "career" may be short.
Carl H wrote:i still say swap it in stock and learn the car from there, the stock setup is enough to get you into trouble.
Kansei240sx wrote: I say learn how to drive that thing for about a year learning the cars full limits and potentials while you build up that RB.
You're making a very vast and huge mistake if you're jumping into drifting without knowing how much grip the car can hold.
monkeyofdrift wrote:what we all been trying to say is learn 1st then play. If you rush to it then you pay for it, and plus I don't want any wannabe drifters drifting over my dog, leave that in the track.
/thread
